failed MAP sensor symptoms
Old Mar 24, 2014 | 08:35 AM
  #16
1994slomaro's Avatar
Re: failed MAP sensor symptoms
Originally Posted by n2oCamaro
My stumble turned out to be a failed coolant temp sensor. The temp. reading would jump around making the pcm switch to open loop and back.
Are you talking about the temp sensor in the waterpump? I am having the same problems and switched opti and temp sensor in the pump and still runs bad.
Old Sep 9, 2014 | 04:32 PM
  #17
wlw-19958's Avatar
Hi There,
Originally Posted by shoebox
You can replace it with a new pigtail. Comes with crimp connectors or you can strip, solder and heatshrink.
1993-1997 MAP sensor pigtail
AC-Delco #PT123
GM p/n 12085502
Also possible that you could find a new connector at your local auto supply.
If you just need the plastic connector (without the pigtails) you can get
them from some electronics suppliers. For example, the green connector
for the MAP sensor is Delphi part No: 12020403-B. I've been getting
them from Mouser Electronics. If you are buying less than 25 of them,
the price is $1.11 (I bought 5 of them). Also, you will need the dis-
assembly tool to get the terminals out of the old connector. You can find
an inexpensive Weather-Pack tool on eBay.
Good Luck!
-Blue Chips-
Webb
Old Sep 9, 2014 | 06:16 PM
  #18
timnfxr's Avatar
Wouldn't it have been easier to just buy the entire pigtail?
MAP Sensor Pigtail
Old Sep 9, 2014 | 06:45 PM
  #19
wlw-19958's Avatar
Hi There,
MAP Sensor Pigtail
It all depends on how much money you want to spend and how much work
you want to do. The pigtail you show is $11.50 and the connector I
mentioned is $1.11 and the tool can be had for $6.00. Popping the Weather
Pack terminals out of the old connector is much easier than cutting and splicing
in a pigtail assembly; especially if you are going to solder the connections.
Also, if you are getting the connector assembly from GM
or ACDelco, the pigtail wires are usually NOT color coded.
It boils down to what you feel comfortable with.
Good Luck!
-Blue Chips-
Webb
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Fatdog2
Feb 13, 2015 08:19 PM
