Failed emissions, what do I need to fix?
Old Jan 4, 2005 | 02:07 PM
rlax31's Avatar
I failed the emissions test today. It failed at 15mph, but passed at 25mph. The guy at the station said that it could be one of two things: The cat, or the EGR.
Performance mods are as follows:
GMMG cat-back, A4-M6 swap, SLP intake, SFC's, 4.10 gears, throttle body bypass.
What do you think is wrong? Most likely a malfunctioning EGR valve? cat going bad? Both have never been touched since I've had the car.
Old Jan 4, 2005 | 02:29 PM
JBird33's Avatar
Re: Failed emissions, what do I need to fix?
I think a bad EGR would throw a code, do you have any codes showing?
Old Jan 4, 2005 | 06:11 PM
rlax31's Avatar
No codes
Old Jan 4, 2005 | 07:33 PM
StickMaster's Avatar
Doesn't have to show a code, how many miles?
Old Jan 4, 2005 | 07:40 PM
rlax31's Avatar
57k
Old Jan 4, 2005 | 07:53 PM
How bad did you fail? make sure its good and warmed up and throw some revs before you go in there, clear all the crap out, or hold a high idle for a little bit before you go through. you can also run some of the "Guarenteed to pass" crap, or put some holes in your exhaust after the 02s but not too close to the tips (so they cant see/hear them)
Old Jan 4, 2005 | 09:13 PM
rlax31's Avatar
at 15mph the NO ppm limit is 586, and I read 685
at 25 the limit is 531, I read 334
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
zFrank
Aug 12, 2015 03:46 AM
zajones
Jul 30, 2015 02:18 PM
Boss002
Jul 24, 2015 10:47 AM
