Failed emissions with hotcam....!
Old Jan 29, 2003 | 12:13 PM
  #16
sc1twntrbo's Avatar
how bad did you fail by what arer your numbers so we have something ot play with
Old Jan 29, 2003 | 01:01 PM
  #17
Tech's Avatar
A) How do they test your car?
B) What part of the test did you fair on?
C) Does your car still have EGR?
D) How old is cat?
Old Jan 29, 2003 | 01:12 PM
  #18
QUASARBLUEZ28's Avatar
I just went through the sniffer here recently with the H.C. and mods below. I am sure its probably the temp that screwing you up but even with a 160 stat and a very cold day I had no problems.
Standards/Actual reading
HC- 1.1000/0.0420
CO- 20.0000/0.2110
NOx- 2.3000/0.0040
CO2- na/40.7763
Old Jan 29, 2003 | 01:42 PM
  #19
neil350's Avatar
With out knowing exactly what your car failied on its all just a shot in the dark.
Old Jan 29, 2003 | 03:02 PM
  #20
speedmiser's Avatar
Dave, what gear was the car in when they made the test?
I'd try 2nd gear if I were you. Higher gears may load up the motor too much on the dyno and cause you to fail. You'll want as little load on the motor as possible during the pull/test.
Old Jan 29, 2003 | 03:20 PM
  #21
FormulaDave's Avatar
High Speed (25 mph)
Standard/Current Reading
HC 108/475
CO .60/5.26
Low Speed (15 mph)
HC 112/196
CO .62/.02 <- Pass
i wasnt there but my dad said he thinks the guy had it in first gear...car still has all the emisson stuff from the factory on it...
Old Jan 29, 2003 | 04:30 PM
  #22
ttt
Old Jan 30, 2003 | 01:28 AM
  #23
anyone??! ttt
Old Jan 30, 2003 | 02:07 AM
  #24
bunker's Avatar
check to see you have no bad wires, misfires will do this, make sure you're o2's are good, timing might be a bit high at idle/etc... mostly for performance causing you to do bad for HC, high CO would indicate lots of fuel aswell.
Hehe, 93's going from 100* up I remember when I had mine
Old Jan 30, 2003 | 09:45 AM
  #25
yea lots of fuel is prolly from the AFPR, i got that thing cranked up pretty high...im gonna turn it down pretty low this time before i go up there
Old Jan 30, 2003 | 08:31 PM
  #26
finally gave up on it and took it to a local auto electric shop that was recomended to me...ill found out saturday what was wrong hopefully.
Old Jan 30, 2003 | 10:32 PM
  #27
Tom 97ss #25's Avatar
Eds LT4 Hot programming has been known to run a little rich
FYI
Old Feb 1, 2003 | 12:01 PM
  #28
well i just got the car out of the shop and they didnt fix ****...they tested the continutiy of the o2 wires and they arnt burnt in half...they claim that the fact that the computer throws the 13 and the 63 means theres nothing wrong with it....at this point i am TOTALLY stumped...i cant even find anyone compenent enough to work on the car...the only thing i can think to do is take the headers off and put the stock internals back in so the gm dealership will actually work on it....bout ready to sell the pos at this point.
well ive been thinking...the o2s used to work even with all the mods i have and it seems like they started messing up when i rounded off a header bolt and had to take the driver side header bolt off....well my dad told me i needed to put silocon seal on the header and im thinking that maybe that made the o2 go bad...
Old Feb 1, 2003 | 02:40 PM
  #29
ttt, anyone have any ideas....??
Old Feb 1, 2003 | 03:08 PM
  #30
anaik's Avatar
Not an expert on this, but isn't high HC and CO a sign the cat is going.
