failed emissions....help please...
Old May 18, 2006 | 01:21 PM
mysteriousgyrl's Avatar
fail emissions no2 ( or something like that). It was basically double the limit it should have been. everything else passed. any ideas of where to start looking first? Thanks in advance...
Old May 18, 2006 | 01:24 PM
1SlowFormula's Avatar
Re: failed emissions....help please...
well what is done to your car? do you have a cat? are your O2's up to spec?
Need more info please, now is not the time to be mysterious... hehehe
Old May 18, 2006 | 01:52 PM
yes it has a cat, i just had one o2sensor changed 2 weeks ago but I found out today there's more than one. and i had a egr (or something like that) valve replaced last week before taking the test. They did the tail pipe test. Sorry not real good with cars or parts..
Old May 18, 2006 | 02:39 PM
valter's Avatar
Engine can be running lean to get high NO2. Most likely it's bad O2's or EGR not functioning properly.
Old May 18, 2006 | 03:15 PM
EnerjetF67's Avatar
Usually when one fails for NOx the culprit is the EGR, possibly an O2 sensor but usually O2's going bad cause richness, not lean which would cause high NOx.
When an O2 is bad, usually one would fail for HC/CO not NOx.
Thank god I'm in Michigan where we have absolutely ZERO emission testing !
Old May 18, 2006 | 04:57 PM
Here in PA you aer exempt if you can keep the milage below 5K per year...
That's pretty easy to do if you have 2 gage clusters.
Old May 18, 2006 | 06:31 PM
96flame's Avatar
Is the car stock or do you have headers on it, aftermarket tuning. Nox can be caused by too much ignition timing, lean conditon, too hot combustion chambers. The key items used to control Nox are the Catalytic converters and EGR system. Its possible for cats to fail only on Nox but EGR is usually the culprit.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
Boss002
Jul 24, 2015 10:47 AM
Hawk
N2O Tech
10
Feb 3, 2003 02:31 AM
copper88iroc
3rd Gen / L98 Engine Tech
Dec 13, 2002 04:56 PM
