Failed Emissions because of EGR valve, my headers? ---
Old Oct 13, 2006 | 02:36 PM
AlwaysCode390's Avatar
Angry Failed Emissions because of EGR valve, my headers? ---
Hey guys, well its time for me to re-register my plates and I couldnt pass emissions testing. They just plug into the obdII under the dash and since it had ONE code (EGR 0400 ) they said it FAILED.
I bought a new EGR valve a few months back, but after reading on here, I think its my current exhaust setup causing insufficient backpressure. I am hesitant on replacing it because it may not fix the problem.
Is there a way to trick it into NOT throwing a code and NOT saying "NOT READY" when tested? Thanks guys....I have two weeks to figure this out!!! Then its time for the LE2 install ... thank God for 2 yr plates ---
Old Oct 13, 2006 | 02:45 PM
2000GTP's Avatar
Re: Failed Emissions because of EGR valve, my headers? ---
I got the same code when I did my long tubes. Madz28 was able to tune it so the EGR would work around the "less backpressure" issue. After that, it passed with flying colors.
Old Oct 13, 2006 | 04:54 PM
Awesome. The only problem is I am about to get a wideband tune after I get my le2 package put in (about a month to go). I would hate to pay $160 for a tune I will erase in a month , damn ... and I only have 2 weeks!!! I thought if I erased the code and drove for about 20 miles, I would pass like I did last year, but the code shown up after 3 miles this time!!! ---
Old Oct 13, 2006 | 09:44 PM
bingo's Avatar
MadZ28 has it set up where he will reflash for $50 after the first time. I guess you need to decide if it is worth it to pass emissions. Ion had my PCM back in about a week.
Old Oct 15, 2006 | 04:37 PM
Ok, thanks for the advice. I originally was going to go with Madz28 for my tune, but was talked into a real wideband tune for $100 more from my mechanic. Damnit ---
Old Oct 15, 2006 | 05:39 PM
There's a circuit that some people have used to trick the PCM into thinking the EGR is operating. It involves using the EGR vacuum solenoid signal to insert a resistor in the MAP sensor wiring, simulating the change in MAP pressure that the PCM looks for when it does the diagnostic and cycles the EGR valve, while monitoring the change in MAP.
Try a "search"..... someone has posted a link to the circuit in the past.
Old Oct 15, 2006 | 05:45 PM
96flame's Avatar
I would get a second PCM so you can swap it when needed. I happen to have a spare out of a 96 if you need one.
Old Oct 15, 2006 | 06:22 PM
Thanks Injuneer, I will SEARCH for that.
Flame....does your pcm have an egr delete tune on it? Thanks ---
Old Oct 15, 2006 | 07:57 PM
96flame's Avatar
Its completely stock never been tuned
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jocamino
Dec 29, 2014 10:15 PM
