Failed Ca. smog check NOX
Old Sep 12, 2011 | 01:38 AM
  #16
Fatdog2's Avatar
Re: Failed Ca. smog check NOX
Before you dump money into this,take the car to Chris at VIP auto repair.he knows these cars inside and out.He is on Soledad,across the street from home Depot.(Ruther street i think).My02.He is a GM demi God.Hope this helps.
Old Sep 13, 2011 | 02:20 PM
  #17
wbacall's Avatar
Cell 16. I'll check again later today. I'm going to add an extra ground between the engine & the body, I get about .5 volts while cranking.
Thanks,
Walter
Old Sep 14, 2011 | 05:27 AM
  #18
Cell 16 is only for idle. Aren't they testing the engine under load, at two different RPM? You have to get the LTFT's for EVERY cell, not just the idle cell.
Old Sep 25, 2011 | 03:39 PM
  #19
wbacall's Avatar
Took the car to a shop that can also check the tailpipe emissions. They did a top engine clean out 3 times & then had to replace the O2 sensors again. The car finally passed.
Thanks for everybody's help,
Walter
Old Jul 29, 2013 | 11:10 PM
  #20
wbacall's Avatar
Here I am again. The car barely passed last time so considering that I had over 300,000 miles on the engine I replaced it with a low mileage used engine. The car failed again this year.
Latest test:
Co2. O2. Hc. Co. Nox
15mph 14.5. .3. 45. .04. 646
25mph 14.5. .2. 38. .04. 626
Car runs great, gas milage is good. Lamda is 1.012- normal. Idles good. Smoke tested for vacuum leaks. No vacuum leaks. All vacuum hoses new. O2 sensors new. No exhaust leaks. Fuel trim is normal. Fuel pressure normal. New delco pump & regulator. Egr valve & solenoid new. Optispark new. Cat is new. Replaced again with higher load cat. Tried forcing egr valve open, no help with nox. Egr flow is good. Egr system tested ok. I have the car at a Star smog station and they are running out of ideas. I am going to replace the injectors next. I also guess I need to do a carbon clean out. Does anyone have any other suggestions? The smog guy said the nox goes down if he forces the car a bit richer I have had this car for 10 years and never even had an issue with smog! Please help.
Old Mar 27, 2014 | 01:30 PM
  #21
XrisZ28's Avatar
Hey did you get your car to pass smog?
Old Mar 27, 2014 | 05:10 PM
  #22
You might want to try an e-mail (left click on his screen name). He has not visited this site since 12/15/13
Old Mar 29, 2014 | 02:24 AM
  #23
wbacall's Avatar
After much stress, anxiety and money I discovered Magnaflow cats don't work for our cars. I installed a walker cat and the nox numbers magically became normal. If you search my name you will find my final resolution. Good luck.
Old Mar 29, 2014 | 01:25 PM
  #24
Chimera96's Avatar
Originally Posted by wbacall
After much stress, anxiety and money I discovered Magnaflow cats don't work for our cars. I installed a walker cat and the nox numbers magically became normal. .
glad you got it worked out....but FWIW I replaced my stock 100k CATS with the MagniFlo OBD2 CARB ones (fing not cheap) years ago and have passed Calif. smog every time....with a 383 H/C motor
for OBD1 cars...any replacement CAT should work
Old Mar 30, 2014 | 03:39 PM
  #25
wbacall's Avatar
"For OBD1 cars...any replacement CAT should work"
They should, but the Magnaflow Cats definitely don't work in our cars.
Old Mar 30, 2014 | 05:23 PM
  #26
Was the cat you installed possibly an ebay "universal" cat with an AIR connection pipe between the beds that you left capped?
Old Mar 30, 2014 | 09:41 PM
  #27
wbacall's Avatar
I had all 4 cat supplied & installed by a reputable exhaust shop. All the cats were California legal. I am service manager at ajaguar shop and have been dealing with them for 10 years.
Old Mar 30, 2014 | 11:05 PM
  #28
If I read this correctly over the course of 3 years you bought 4 different Magnaflow CARB certified catalytic converters, and they would not allow the vehicle to pass the CA emissions test. Didn't you think it worthwhile to confront Magnaflow on this problem?
Something isn't adding up here.
Old Mar 31, 2014 | 01:48 PM
  #29
wbacall's Avatar
Tech support at Magna flow recommended trying another brand cat. I wonder if the Magnaflow cat has too little back pressure to work with our egr system. The magnaflow cats were all 3" and the only carb cat by walker was 2.25". Much closer to the OE cat.
Old Mar 31, 2014 | 02:17 PM
  #30
Chimera96's Avatar
wba
you live in SoCal, me to. What I found is since this "STAR" fing smog test deal happened muffler shops will not install any CAT on a OBD2 car (yours is OBD1 so you may be OK) that is a different size than what came stock on the car.
My car came with 2 1/4" CATS but I bought 2 1/2" CATS (my car is a B-Body) back before this STAR deal happened. 2 1/2" is what the Vette LT1's have
Odd Magniflo said to try another brand. But for me their CAT works fine and has passed smog since installing them
For your OBD1 car I would think any CAT approved for Calif would work. Walker, Catco, etc
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
