factory oil cooler?
Old Jun 6, 2004 | 10:39 AM
FLU
Guest
Posts: n/a
factory oil cooler?
94 z28 auto now how do i know if i have a oil cooler? i have two lines coming from where the oil filter mounts up. one lines goes to the radiator and the other to the water pump so does this mean i have a oil cooler? Thanks Jeff
Old Jun 6, 2004 | 10:49 AM
Bralgar's Avatar
Yes, but just remember they are coolant lines and not oil lines though. Aftermarket oil coolers actually route the OIL through acooler and back to the block.
Old Jun 6, 2004 | 10:59 AM
FLU
Guest
Posts: n/a
ok so i don't have a factory oil cooler then?
Jeff
Old Jun 6, 2004 | 11:04 AM
Bralgar's Avatar
Yes you do have a factory oil cooler, it is just that the factory cooler routes coolant around the oil as it passes through the oil filter to cool it.
I was just pointing out that an aftermarket oil cooler is better, and trying to explain that the factory cooler doesn't route the oil from the block as an aftermarket does.
Sorry for the confusion.
Old Jun 6, 2004 | 11:08 AM
FLU
Guest
Posts: n/a
alright thats cool - haha thanks for the help -installing a s-trim and they said if you have a factory oil cooler you have to mod somethings for the SC
Thanks Jeff
Old Jun 6, 2004 | 12:51 PM
southern78's Avatar
Do you need a oil cooler? I am running without currently. 95 z28 setup in a s10.
Old Jun 6, 2004 | 01:24 PM
gb95zconv's Avatar
Thanks Jeff
Yeah....you cant use the factory oil cooler for the SC.
Old Jun 6, 2004 | 01:27 PM
gb95zconv's Avatar
No....the factory one is pretty worthless anyway.....I never put mine back on when the 383 went in.
Old Jun 7, 2004 | 10:42 AM
flusz28's Avatar
gb95 - how long has your oil cooler been out of the car? you have never had any problems? factory put it there for a reason so i think i might keep mine in. thanks
Old Jun 7, 2004 | 01:07 PM
Bralgar's Avatar
Nope, it was an option.
Old Jun 7, 2004 | 02:29 PM
BUBBA's Avatar
Ok, was the oil cooler installed as an SLP (SS option) considered an After Market cooler? From your explanation, I would say "yes" since I believe the oil is actually routed through the cooler.
If, as you say, that the A-Market cooler is better, how so?
Just curious, since if the oil is actully routed through the cooler, wouldn't it be necessary to clean the cooler when you change your oil lest any dirt or debris remain in the cooler even after the oil and filter are changed?
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
cmdeshon
Dec 12, 2014 10:51 PM
97 RedSS
Jun 10, 2003 07:58 PM
