factory lt1 springs
Old Jun 28, 2012 | 04:03 PM
Lilatlboy6969's Avatar
factory lt1 springs
ok im looking for some after market springs to go with the scorpion lifters i've selected to use with my mostly stock lt1.. i know i'll also need a tune im just having a hard time finding some really good valve springs to go with these rocker arms.
Scorpion Performance SCP1036BL - Scorpion Narrow Body Self-Aligning Rocker Arms - Overview - SummitRacing.com
anyone know some good valve springs other than lt4 springs that would go well with these and the rest of the stock drivetrain?
Old Jun 30, 2012 | 09:15 AM
Re: factory lt1 springs
still in search of the factory spring specs... i've google'd it and its not pulling up the info im in search of..
Old Jun 30, 2012 | 11:02 AM
pgerst's Avatar
1995 GM manual specs:
Free height - 2.01"
Install height - 1.78"
Seat Pressure - 81 to 89# at 1.78"
Open Pressure - 252 to 272# at 1.305"
Also have measured the following:
OD - 1.300
ID - .875
Bind - 1.260
Old Jun 30, 2012 | 12:08 PM
96capricemgr's Avatar
The factory springs aren't that good for stock cam and stock 1.5 rockers so who cares what the specs on them are.
With 1.6 rockers and a stock cam LT4 springs are a good way to go, think they are a whole $35 a set.
If you think more serious heads/c am upgrades are in the future I would at least consider 7/16" studs/rockers and guideplates now then what you have will grow with you instead of replacing it all as you mod further.
You do not buy overkill springs to match a later setup because in a performance application springs should be considered a wear item once you get into aggressive aftermarket cams.
MadMav
Feb 6, 2015 11:02 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
