Factory GM part # for fuel pump harness?
Old Aug 1, 2006 | 05:41 PM
Javier97Z28's Avatar
Moderator
Is this even replaceable?
I'd like to replace the harness from above the tank down to the chassis connector. I believe the ground pin on the harness where it connects to the chassis connection is where my problem lied. (No start, fuel gauge pegged past full).
I've closed up the pin some but I'd like to replace it completely. I have the correct pigtail if necessary from my racetronix pump wiring kit that I opted to remove from the car, but I'd rather keep it intact in case I decide to reuse it in the future.
Anyone have the part #? couldn't find it on shoebox's site and I'm having trouble finding it in the 93-97 parts breakdown PDF.
Thx!
Old Aug 2, 2006 | 08:25 PM
Moderator
Re: Factory GM part # for fuel pump harness?
Anyone?
Old Aug 2, 2006 | 08:58 PM
hey01's Avatar
http://198.208.187.182/internet/Vehicle.jsp
Old Aug 2, 2006 | 09:17 PM
Moderator
Hrm, looks like they don't sell it separate according to that:
http://198.208.187.182/internet/Vehi...e=22&part=6258
Old Aug 3, 2006 | 07:51 AM
hey01's Avatar
ouch, thats not good
Old Aug 3, 2006 | 11:10 AM
Moderator
It's ok, I'll just replace the pigtail.
Old Aug 4, 2006 | 06:12 AM
TQdrivenws6's Avatar
Please update this when you make any progress....Mine just did this last night and I was able to unplug the harness, tighten the pins up, and plug it back in. It has taken some abuse since then and still works fine but I would like to do a more permanent fix.
Old Aug 4, 2006 | 07:07 AM
Moderator
I'll see what I can do. At this point I think I'm going to get some high quality butt connectors that are very secure, and splice in my slightly used racetronix pigtail since I'm not using their harness. I'll heatshrink wrap the splice.
Old Aug 4, 2006 | 07:34 AM
I am using the Racetronix harness so the wires going into that pigtail were tight, but the pins in the recieving harness (funky pass through on the body) had a little play in them.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
