A/F Gauge question
Old Oct 25, 2003 | 03:50 PM
Revenant's Avatar
Question A/F Gauge question
Hey yall,
When installin an A/F ratio gauge should i into the pre-cat or post-cat o2 sensor? Also, I have dual cats so would it matter if i did the left or right side?
Old Oct 25, 2003 | 04:35 PM
ny_z28man's Avatar
Hey man, run pre-cat. Left or right side it doesn't matter. You can run both if you want. Hook up a dual position switch and run left and right. This way you can see variation and both will (should) give you an accurate reading. see-ya,
-Paul
Old Oct 25, 2003 | 06:19 PM
kgkern01's Avatar
I have heard that unless you are running a wideband O2, then you aren't really going to get an accurate A/F ratio reading. The factory O2's are only setup to read rich, stoic, or lean, from what I understand, please correct me if I am wrong.
By the way, how much do wideband O2's run? A few hundred right?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Feb 17, 2015 10:51 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
