EXTREMLY bad vibration when i turn...Please Help.
Old Nov 8, 2003 | 12:23 AM
drewstealth's Avatar
Well i had this problem since i have got the car 7,000 miles ago. But its starting to drive me crazy again. So now that i want to figure out what it is. If i'm at a stop and turning either right or left i get a really bad vibration. My whole transmission starts to shake. But it will only do it as long as i'm giveing it gas. It does it also when i'm going slow around a turn, but not always. If i'm going fast it doesn't do it though. Any ideas on what it could be? I did it before when my tires were bald, and it still does with brand new tires. I have a poly tranny mount that is not broken. Other than that i'm open to suggestions. Thanks.
Old Nov 8, 2003 | 06:21 AM
slopokrodrigez's Avatar
If your sure the tranny is thumping when you turn corners then I would have to say your problem is in the differential. Assuming that your clutch is ok. Remember your letting the clutch out or putting it in when turning. But if the clutch were the problem you would have straight line problems also. It has to be the diff.
Try checking it with both rear wheels off the ground. Put tranny in neutral. Try having one person hold one rear wheel while the other person turns the other rear wheel.
Good luck
Old Nov 8, 2003 | 11:55 AM
Okay i will try that tomarrow. Thanks. Any other suggestions?
Old Nov 8, 2003 | 02:57 PM
Kataklysm's Avatar
The hub assemblys are probly worn out, the same thing happened on my old car.
Old Nov 8, 2003 | 03:07 PM
Sorry if i sound sort of dumb but what is a hub assembly? Where is it located?
Old Nov 8, 2003 | 03:34 PM
Kataklysm's Avatar
Its on the axle on each side, u have rear and front hub assemblys...its what actully allows the wheel to turn. I"m having trouble explaining this haha.
Old Nov 8, 2003 | 04:26 PM
Gos2Slo's Avatar
Hey Drew, it might be your motor mounts are loose or broken, just another thing to check. Or maybe something in the suspension is loose.
I dunno, if it were a FWD car I'd guess a CV joint, heh.
Hey, just noticed you're in Fairfield..I'm just over in Napa. We should meet up sometime and help each other out.
Cheers,
Chris
Apr 16, 2015 09:57 AM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
