Extreme Duty guys in here ...
Old Nov 6, 2003 | 08:43 PM
S.J.S.'s Avatar
Hey guys...installing my LT4 Extreme duty timing chain. I was curious. Is there supposed to be play in the chain. I know the stock one didn't have any. But this one appears to have quite a bit.
thanks...
Old Nov 6, 2003 | 08:51 PM
Z95m6's Avatar
i believe they are suppose to be pretty loose. I have a extreme duty, but i never tried the stock crank gear. Thunder racing sells an oversided gear to take up the slack and thats what i bought. When i put that on it was nice and tight. I would recommend getting one.
Old Nov 6, 2003 | 09:03 PM
S.J.S.'s Avatar
Anyway, the more I look at it...its like a bike chain and any other type of roller. I know they are supposed to have play. Just wondering if its the same for this application.
Old Nov 6, 2003 | 09:09 PM
gb95zconv's Avatar
Mine had some play....but not too bad.
Old Nov 6, 2003 | 09:11 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Quote- Mine had some play....but not too bad. -Quote
Same here.
Chris
Old Nov 6, 2003 | 10:21 PM
VeryBad's Avatar
I was concerned about the slop in mine so I called the guys at Lingenfelter and was told that it wasn't an issue. Still would have felt better if it was tighter.
Gordon
http://witchhunter.com
Fuel Injector Cleaning & Flow Testing
Old Nov 6, 2003 | 10:30 PM
S.J.S.'s Avatar
Anyone else. I wanna close this boy up. I would say it moves like 1/8th inch.
Old Nov 7, 2003 | 12:44 AM
96 WS6's Avatar
With the car running, the chain will have slack on one side and be tight on the other. That's just how it works, so yes, there should be a small amount of slack in the chain.
Old Nov 7, 2003 | 08:39 AM
LT4POWR's Avatar
I also got the oversized crank sprocket from TR. Slack
Old Nov 7, 2003 | 09:15 AM
Don 97 SS's Avatar
I did not notice much slack when I installed the LT1/LT4 ED timing set. It certainly was tighter than the loose and whimpy oem chain that I removed.
Sergio
Jan 27, 2016 04:27 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Red97LT1
Aug 7, 2002 05:45 PM
