View Poll Results: Did your break or not, and how many miles
Yes
8.33%
No
11
91.67%
Voters: 12. You may not vote on this poll
Extreme Duty Chain , Breakage?
Old Sep 28, 2005 | 06:06 PM
Steves396lt1
Guest
Posts: n/a
Seems a few people are having the Extreme Duty chain break, actually the big gears teeth are going bad because of where problem associated to Water pump drive gear. One guy even found a Rockwell hardness on the Extreme duty was lower than the factory gear(big gear) and the water pump, basically saying the Extreme Duty gear was softer metal and not heat treated correctly, which Cloyes has no idea why, according to the guy that did the test.
Old Sep 28, 2005 | 06:56 PM
1racerdude's Avatar
Re: Extreme Duty Chain , Breakage?
If they didn't have the oil plugs with the .030 holes in them, at the end of the lifter galleys,it wasn't getting lube.
Cloyes makes their own and the chains for the General and if your engine has the oil holes ya won't have a problem.
I run one with 260# seat and 780# nose spring and have had NO priblems. Another thing if ya don't change both gears for the WP ya gonna have trouble.
The problems ya speak of is due to improper installation, not the fault of the timing set.
Old Sep 28, 2005 | 07:01 PM
Steves396lt1
Guest
Posts: n/a
HHMM, just curious how you could install it wrong. If you replcae all the gears, line them up, how could they be installed wrong. I have heard of people not replacing the WP gear, lazy I guess, but Cloyes says they are same hardness. But, mine as well as others, are serialized. SO, you need to put all gears in the kit in your motor, so is that the improper install you are speaking of, not putting the gears in from the kit?
Old Sep 28, 2005 | 07:15 PM
1racerdude's Avatar
Did ya read the part about the oil plugs?
Old Sep 28, 2005 | 08:10 PM
Steves396lt1
Guest
Posts: n/a
I know about the oil plugs. But what does that have to do with install. If a person takes the cover off, and puts the chain in, where does the plugs come into play, unless it was a new engine build. SOme people just replace the timing chain and gears. Why would they inspect an oil hole? They wouldnt unless someone told them.
Old Sep 28, 2005 | 08:29 PM
1racerdude's Avatar
Exactly,If ya don't know what ya are doing it's best left to them that do and that includes oil holes that most don't know about.
If ya don't know about the oil holes in the plugs from a rebuild or don't check them for being stopped up that is a improper install. If the gears or chain don't get the proper lube it fails.
Do ya know if this was checked on the ones ya "heard" about. And there are occasions when the crank sprocket don't line up due to the chamfer on the snout.
That is the best picture I can draw ya.
There is nothing wrong with the ED timing set.
Old Sep 28, 2005 | 09:02 PM
Steves396lt1
Guest
Posts: n/a
Okay, you are taking this thread where it doesnt need to be going. Read the post, do a poll, and if yours broke state it. The oil plugs are one of many things that can happen to a motor. Lets stay the path. Okay
The ED timing chain is a very good product(allot of my friends use it in long distance type racing), but a few have had problems, and I am trying to find out the problem, wether it be mechanical or the person, thats all.
Old Sep 29, 2005 | 03:08 AM
Z95m6's Avatar
mine hasn't broke after 35k.
Old Sep 29, 2005 | 12:50 PM
Steves396lt1
Guest
Posts: n/a
ttt
Old Sep 29, 2005 | 07:07 PM
cehan's Avatar
Good point about the oil holes. When I got my new 383 short block, I noticed that the plugs weren't drilled like the factory plugs. The factory holes were #70 drill bit size (.028"), so I drilled them to match. If you look at the back of the water pump drive gear it even has oil grooves, which I imagine is to lubricate the cam sprocket when it rubs on the cam retrainer plate.
Chris
Old Sep 29, 2005 | 07:17 PM
Steves396lt1
Guest
Posts: n/a
Chris
Thats why I have the rebuild the LT1/4 book. Little things make a HUGE difference. I pre lubed my gears with cam lube prior to start up also.
Old Sep 29, 2005 | 08:10 PM
NJLT1SS's Avatar
I have the ED timing chain for the past 8K miles, no problems here. I dont have the oil holes drilled out in the oil plugs.
Nick
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
karpetcm
Aug 14, 2015 03:02 PM
