extra hose???
Old Jun 16, 2004 | 08:58 PM
ericz28w's Avatar
Unhappy extra hose???
i just got done putting new water pump in and my new pump has one less small hose fitting, that would of took the hose from the bottom right of the radiator (drivers side) am i gunna have to take everything off again, or can i just put a plug in the hose???????
Old Jun 16, 2004 | 09:15 PM
CeeBee94Z's Avatar
Did you get the LT1 water pump that was designed for the Impalas? I have a feeling thats what happened because I believe that they have one less tube coming out of it.....
Old Jun 16, 2004 | 09:46 PM
ericz28w's Avatar
it is part number #12527739 which is the number some one gave me when i asked for the part number.
Old Jun 16, 2004 | 10:31 PM
That is a Corvette pump. They don't use the bypass hose, because they don't have an oil cooler option. You could probably plug the radiator hose without adverse effects.
The F-body pump is 12527741, as shown on my part numbers page.
The Impala pump is 12527240.
Old Jun 16, 2004 | 11:05 PM
ericz28w's Avatar
do you think that would be a good idea, or should i just go through the hassel of returning it.
Old Jun 16, 2004 | 11:14 PM
If not installed, I would get the right one. If installed, not sure what I would do. I guess I would be more comfortable with the right pump, but be tempted to plug the hose.
Pump differences
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
