External trans cooler, through the radiator first?
Old Jun 7, 2003 | 08:15 AM
FASTFATBOY's Avatar
When mounting an external trans cooler, is it better to skip the radiator all together? This car will be street driven in very hot summer heat with a/c.
David
Old Jun 7, 2003 | 08:23 AM
sssalah's Avatar
Trany to radiator, radiator to cooler, cooler to trany.
Its a bad idea IMO to bypass the radiator. Air is much less efficient as a cooling media than water, and u'll not get enough cooling if you did in stop and go trafic.
Old Jun 7, 2003 | 10:39 AM
ghostle's Avatar
Going to radiator then cooler then back to trans. is suppose to be the most effeicent way.
james007moore
Jan 1, 2016 01:14 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
CARGASM
Sep 4, 2002 11:17 AM
