Exhausted all my ideas...advice please
Old Feb 24, 2004 | 09:10 PM
rocmemphis's Avatar
Question Exhausted all my ideas...advice please
For the past few weeks I have had a mysterious ticking/clicking that speeds up with acceleration and never ever goes away. I knew I had a few exhaust leaks so I pulled my headers and replaced the gaskets. All the exhaust leaks were sealed but I still have the noise. So I replaced the spark plugs and the wires. Tick is still there. I drained the oil to look for metal shavings or chunks....nothing.
Mods that I have:
LT4 Hotcam
CC Pro Mags
Crane springs
MAC headers
PCMForLess tuning
The temp is normal. Oil pressure is normal. Only thing weird is that the car will stall out sometimes if I go from D to Reverse and also sometimes the idle is lopey.
Any help would be appreciated.
Old Feb 24, 2004 | 09:15 PM
badblackta's Avatar
um check your rocker arms. Make sure they are properly tightened. And about the idle being lopey, um duh, its a hotcam, its gonna lope some
Old Feb 24, 2004 | 09:21 PM
rocmemphis's Avatar
Well I know it is supposed to be lopey but since the program raised my idle to up around 800 all of sudden it likes to dip to around 500 when I almost come to stop and then revs back up to 800.
Oh and about the rockers I have readjusted them 4 times in the last month.
Old Feb 25, 2004 | 09:24 AM
rocmemphis's Avatar
For the day crew....
Old Feb 25, 2004 | 09:56 AM
brn_em_up13's Avatar
A friend of mine had a similar issue where his car would drop to about 500 and almost die...and then jump back up again. After a couple months he finally learned that a fuel injector had gone bad and once that was fixed the problem totally went away.
not sure....cuz im no car expert but just a thought that you mihgt want to check that out. good luck.
Old Feb 25, 2004 | 09:58 AM
Ricardo's Avatar
Could be a lifter dying.
Old Feb 25, 2004 | 10:16 AM
rocmemphis's Avatar
Lifters are only about 6 months old and it really isnt a lifter type tick.
I am thinking that maybe my roller rockers are just really loud
Old Feb 25, 2004 | 10:42 AM
indieaz's Avatar
As mentioned above - check valve lash. Sounds like rockers are too tight.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
