exhaust setup, current vs. possibilities
Old Apr 18, 2005 | 09:30 PM
69z-28's Avatar
ok i have the car in my sig, with a very messed up exhaust. its all stock, but goes from the pipe over the differential into a straight pipe welded in place of the muffler and the pipe goes over the diff. then over the other pipe and "T"s into it. for an easier idea i drew this in paint.
http://img.photobucket.com/albums/v3...93Zexhaust.bmp
it sounds decent but as you would expect it is quite restricting. so right now there is no muffler and its very restrictive. i want, less restriction and a louder and meaner sound. i will try to get a sound clip sometime so everyone can hear what it sounds like. im not sure if i should do something with were it "T"s in and try to do something with more of a Y like how it connects on the loud mouth or something, and also i was wondering if i put a dynomax bullet in the pipe like the loudmouth is setup, would that make it sound any different, like louder or somethign or just quite it or what. as of now it sounds good but its not as loud as you would think with no muffler. i will try to get a sound clip, but any oppinions or anything at all are very welcomed and appreciated. BTW im on a tight budget and want to spend the least money and try to work with what i have. thanks
Old Apr 18, 2005 | 10:00 PM
lookingforwheels's Avatar
Re: exhaust setup, current vs. possibilities
You aren't going to want to hear this but you will be much happier in the long run if you just save up your money and do everything right. Headers/Y-pipe/cat-back or Headers/true duals. You will get the best flow that way as well.
Old Apr 18, 2005 | 10:07 PM
95_LT1_6SPD's Avatar
Best sounding exhaust for a 4th gen, is gmmg. NO if ands or buts, IMO.
http://videos.streetfire.net/Player....B-7973BB783C2C
Thats my car with the mods in my sig.
Old Apr 18, 2005 | 10:14 PM
69z-28's Avatar
i plan on getting LT's in a year or so, but i dont wanna spend a lot more money, basically i know if i do somethign with that "T" it will help out alot with performance but would it be wise to get a 30 dollars Bulley and put it in before the differential. would that make it sound better or any different?
QuickSilver02
Apr 7, 2015 11:12 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jan 5, 2015 07:14 PM
