Exhaust ?'s, simple
Old Aug 25, 2006 | 06:53 PM
CamaroRacing12's Avatar
Exhaust ?'s, simple
Will pacesetter long tubes fit on a stock y-pipe? Also how big is a stock y-pipe on my 95 z28? Also how easy is it to remove the cat and replace it with a straight pipe and then put the cat back on for inspection? Also how hard is it to install duel cutouts after the longtubes on a stock y-pipe?
i kno its alot of ?'s but i really need some good quality anwsers... thx agian guys this forum is the best!
Old Aug 25, 2006 | 09:31 PM
95LT1conv's Avatar
Re: Exhaust ?'s, simple
no you cannot use your stock ypipe. the LTs and ypipe changes the location of your whole system. it will run right next to and parallel with your driveshaft. the cat will be too big to fit next to the DS. most people put dual high flow mini cats on the ypipe
Old Aug 26, 2006 | 03:39 PM
anyone other advice?
Old Aug 26, 2006 | 04:18 PM
97WS6SCharged's Avatar
You're going to spend a ton of money to try to make the stock Y pipe work. Better to just bite the bullet and buy the right pipe with the cats. Installing cutouts isn't too hard, just a little cutting, welding, and wiring.
Old Aug 26, 2006 | 10:01 PM
yea i just want somethin that ic an easily convert to emission passing.... can u make true duals past emissions?
Old Aug 26, 2006 | 10:35 PM
reamo04's Avatar
I dont know why not? You'd just need a good cat.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
