exhaust popping?
Old Aug 2, 2006 | 05:39 PM
frankthetank078's Avatar
exhaust popping?
usually if i were to rev my engine up, while the RPM's fall the exhaust pops. Last night tho i was getting on the car alittle and when i shifted from 1st to second at 5500 it did a single pop...what could this be from? thanks
Old Aug 2, 2006 | 05:40 PM
wrd1972's Avatar
Re: exhaust popping?
This has been discussed a lot, it is said that it is a nrmal LT1 thing. Its is said to be harmless.
Old Aug 2, 2006 | 05:41 PM
1racerdude's Avatar
It's probably excess fuel in the pipes with no cats.
The pop when shifting could indicate valve float.
Old Aug 2, 2006 | 06:50 PM
easyc4's Avatar
probably just too much flow for the engine, back pressue will cause a nice pop when u let off and **** like that.
Old Aug 2, 2006 | 06:59 PM
1racerdude's Avatar
Has nothing to do with flow. It will pop on any car with the cats removed.
Old Aug 2, 2006 | 07:13 PM
redington's Avatar
im saying its because no cats
Old Aug 2, 2006 | 07:33 PM
easyc4's Avatar
well, if u dont ahve cats, thats creating alot more free flow, which causes more backpressue if the system is big enough. I ahve my cats on the car and sometimes i get the pop b/c after the cat i have an s bend thats 3 inches wide with a 18" long 3" wide bullet race muffler with just a turn down after that right about where the rear seat is. way too much backpressue but it sounds mean
Old Aug 3, 2006 | 07:20 AM
BassProCamaro97's Avatar
Heres my take on this. I have a no cat car with 40's series and dumps before the axl, and everytime i let off the gas and not trying to cover the sound with the accelerator it pop/gargles like its blowin fuel bubbles out of my tail pipe. I've been told its normal by many a folk but,
the thing that got me to believe it was this, a fairly new Z06 with exhuast poped like crazy on decel with cats, and my buddys truck, which has cats to straight pipes ( no muffler) sounds like black cats go off in the pipe every now and then.
If you are running no cats the sound is going to be much more apparent in and out of the car. Seeing as my car use to do this ever so slightly bone stock, im not suprised when opened up it sounds a B2 bomber blowing stuff up down the road. I've heard putting a cam in the car will eliminate this but, I'm just going to put a new engine when the time comes for some real HP.
Sorry for the long post but I think it should give you the answers your lookin for. If not sorry to have waisted your 2 minutes
~Jim~
Z28Freak86
Apr 30, 2024 05:37 PM
AdsoYo
May 2, 2018 03:21 AM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
hotrod 5210
Dec 22, 2014 07:28 AM
