exhaust odor inside vehicle
Old Dec 16, 2004 | 02:10 PM
Guggi97_RA's Avatar
I am still dealing with exhasut odor inside my vehcile at idle. I cant figure it out.
WHat would allow exhaust to come in the vehicle? I have even used expanding spray foam where my heater core comes thru the firewall. Still getting the odor.
would a slight header gasket leak cause it? How would it get inside the car anyway even if it did leak?
Adam G
Old Dec 16, 2004 | 02:16 PM
Dave19yz28's Avatar
Re: exhaust odor inside vehicle
if it's only at idle, maybe your collector gaskets are blown out a bit??
Old Dec 16, 2004 | 02:18 PM
Guggi97_RA's Avatar
I did have leaks there, but I just installed Dead Soft aluminum gaskets on the collectors. Still having the same issue.
Maybe my header gaskets are leaking worse than I thought?
I am running copper gaskets and they have been on the car for about 4 years.
Adam G
Old Dec 16, 2004 | 02:36 PM
Dave19yz28's Avatar
might wanna check those gaskets, I just changed my headers gaskets about two weeks ago and the driver side already developed a small leak
Old Dec 16, 2004 | 02:41 PM
Guggi97_RA's Avatar
WHats the best gasket to use? I get confused doing on a search on the subject.... everyone "Hates copper, loves copper, loves aluminum, loves falpro 1406's "..... AHHHHH
Adam G
Old Dec 16, 2004 | 02:45 PM
Dave19yz28's Avatar
to be honest i don't think it will make all that much of a difference...just make sure ya clean up the header flanges and the ports on the heads...I'm using grade 8 locking bolts right now, but think i'm gonna try the ARP's next time...that 8mm head makes getting a box wrench on them childsplay....
Old Dec 17, 2004 | 08:17 PM
blwnlt4's Avatar
i think you answered your own question of which gasket is best... you went 4 years without blowing header gasket, your lucky to get a year out of a set of paper gaskets.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
95chwagon
Feb 28, 2015 12:02 PM
