Exhaust Manifold Tap
Old Jan 2, 2006 | 07:55 PM
Z28LT1_Just_Nasty's Avatar
Instead of just replacing the gaskets I've decided just to go and buy long tubes. I'm leaning towards x-pipes, but can you run cats with that? How much should long tubes, x-pipe, and whatever else I need run me?
Old Jan 2, 2006 | 08:28 PM
96flame's Avatar
Re: Exhaust Manifold Tap
Your post is kinda confusing but I'll try and help ya out a bit. Your looking at getting longtubes and want to run true duals with an x-pipe and cats? If that is correct then it'll be a minimum $1000. You would need the headers, 2 cats, x-pipe, 2 mufflers and have an exhaust shop make up the pipes for it to be joined together.
Old Jan 2, 2006 | 10:19 PM
I'm trying to get through inspection right now with the manifold tap, its not too noticable on warmer days. On cold days forget it its loud as hell. So if I manage to get through inspection I'm good for 2 years. I was rejected in september for some minor things. My car has been in the shop for the past few months for a mess of problems (manifold tap just came about recently) so I'm overdue by about 2 months on reinspection. Usually they just take a look at the things that I was rejected for so I'm hoping the tap isnt noticed.
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
