Exhaust Manifold question need a little help?
Old Mar 8, 2010 | 01:17 PM
crazypurgatory's Avatar
Question Exhaust Manifold question need a little help?
I had to replace the passenger side Exhaust Manifold because I had a stud brake off and had a bad leak where the exhaust pipe connected to it.
Can I re use these stock Exhaust Manifold gaskets?
They look good and no leaks.
There 3 pieces of metal I just taped them because they were coming loose.
manifold side
engine side
Also is there an easy way of connecting the EGR pipe back on it was very hard to take off?
Does any body know the torque for the 6 Exhaust Manifold bolts?
Thanks,
Old Mar 8, 2010 | 01:41 PM
RamAir95TA's Avatar
For as cheap as a new gasket set would be, why risk it?
Old Mar 8, 2010 | 02:32 PM
The gaskets I have for it are just regular one on metal.
It was very easy to take off the head the hardest part was that dam EGR pipe.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
