exhaust manifold leak, whats more common?
I can't tell if the exhaust manifold is leaking at the head or where it meets the Y pipe. What is more common?
I also heard someone mention they tend to crack...this true?
Originally posted by Kris93/95Z28
Just MHO.....
But there is no in this world I would pull the LT1 manifolds and not REPLACE them with a set of headers.....
I would get some headers and forget those crappy manifolds
Just MHO.....
1. I'm broke as a joke. gaskets $ < header $
2. I am planning on selling the car (see sig)
Manifold to head.. and many times due to a broken bolt[my 94 has the rear drivers side one broken..]
Leaks only on warm start up then goes away.. sounds almost like piston slap..
Charlie
Charlie
Charlie
Charlie
well, I found one of my AIR tubes was really loose. I am hoping that's what the problem was. The previous owner had douched up the threads on the fitting that goes into the manifold. So I pulled both tubes out and plugged the holes. I haven't run the car yet though, I did a few other things (free mods) too and didn't get it back together before dark.
carbon?
Chris Anderson
Jan 27, 2015 08:30 AM
