exhaust manifold leak
There is no gasket to go between the manifold and y-pipe, they use a flange type connection, try tightening the bolts, use some PB penetrating catalist or WD-40 on the bolts about an hour or 2 before you try tightening them, or else you may break the bolts.
Chris Anderson
Jan 27, 2015 08:30 AM
