Exhaust leak..Please HELP!!
Old Jun 8, 2003 | 04:15 PM
Raider Z28's Avatar
I installed the Hooker Cat Back yesterday and took it out for a spin. No leaks at all. As I was returning from my 30 minute spin I heard a leak.
Checking it this morning it is not coming from the Cat Back, but I popped the hood and definetly hear it. Therefore, I think it is a leak in my exhaust manifold or at the fitting that ties into the Y pipe. Also, my "Service Engine soon" light came on. Dame!!!!
Thoughts on what else it could be???? If it is at the exhaust manifold I think it would be a good time to do the Hooker Headers. Thoughts???
Old Jun 8, 2003 | 04:33 PM
jasons93z's Avatar
try to loosen up the 3 bolts where the manifold meets the y-pipe and re-tighten them. I had the same problem. Make sure the 3 bolts are tightened equally.
Old Jun 8, 2003 | 09:45 PM
Raider Z28's Avatar
Found it
I found the leak.
It turns out it was a vac hose came loose. I simply placed it back on and problem solved. Now the :Service Engine soon" light came on when the hose came off. Will it reset itself after awhile since I solved the problem? Or, am I going to have to have it reset?
Old Jun 8, 2003 | 11:28 PM
Reset the computer to clear the code.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
