Exhaust LEak Help!
Old Feb 25, 2005 | 06:21 PM
SS#771's Avatar
Exhaust LEak Help!
Alright I have had an exhaust leak or so i think for quite some time now......it is on the passenger side. I know what an exhaust leak sounds like but it seems to be coming from inside the head almost. All the bolts are tightened down ALL the way. It sounds like a chirping noice almost. another thing a hole for my header bolt got cross threaded and the guy who works on my car cut a bolt in half to get it in there since it would only go in half way. What do you guys suggest? this is getting really annoying.
Old Feb 25, 2005 | 07:18 PM
b4cz2896's Avatar
Re: Exhaust LEak Help!
The leak is probably right there at the point where the head meets the manifold. If the bolt hole is stripped you should retap it and put a new bolt on with new header gaskets.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
