exhaust leak
Old Dec 24, 2006 | 09:44 AM
ihaveacamaro's Avatar
exhaust leak
Hey guys, I recently rebuilt my lt1 and now have a leak coming from the engine bay up through the ac vents. I've checked everything except changing the headers wich i really dont want to do. Would it work if I just used 2 sets of gaskets? I'm thinking the headers aren't perfectly flushed w/ the heads. thanks for any help
Old Dec 24, 2006 | 10:21 AM
DrewHMS97SS's Avatar
i would wager using 2 sets of gaskets would increase the amount of leak. find where the leak is, and work on fixing it.
Old Dec 24, 2006 | 02:15 PM
2000GTP's Avatar
Two gaskets can very well make more of a problem. Are you sure all of the bolts are tight and none of them backed out? Are you also sure that you didn't blow a header gasket altogether. Do you have the EGR connection intact still. If so, check to make sure that the EGR pipe didn't somehow get damaged. Also, check the connection where the header collectors meet the y-pipe and make sure there are no leaks coming from there.
Old Dec 24, 2006 | 02:50 PM
alright thanks, i wasnt sure about the 2 gaskets. i already replaced the first set i had on with the rebuild and those had been burned up a little. no bolts loose though, im gonna check the egr. thanks
Old Dec 24, 2006 | 09:17 PM
hey do you guys know of anything that i could use to locate the leak? i am having trouble. i saw one one post something about seafoam, someone said it would work but ive never heard of it.
Old Dec 24, 2006 | 09:52 PM
byrons1502's Avatar
i use a smoke machine.
Old Dec 24, 2006 | 09:54 PM
how do you use it?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
