Exhaust crackle/pop until closed loop normal?
Old Oct 3, 2004 | 04:15 PM
ChrisS95TA's Avatar
I have the 3 inch single out flowmaster system FYI....until my car goes into closed loop on my scanner the exaust will crackle when coming off of revs, nothing loud like a backfire but enough to hear it from fairly far away. Would this be normal with the type of exhaust I have or should I look into it? Thanks for any tips
Old Oct 3, 2004 | 08:29 PM
ChrisS95TA's Avatar
Re: Exhaust crackle/pop until closed loop normal?
Anyone knw if this is normal? THanks
Old Oct 3, 2004 | 08:47 PM
My 97 Z28's Avatar
Totally normal. My magnaflow does it. I love the sound when is cackles
Old Oct 3, 2004 | 09:59 PM
IrocSS85's Avatar
yeah my flowmaster did it too. and that slp loud mouth does it REAL bad. it has to do with the fuel mixture when the eng. is cold. for some reason, my new edelbrock catback and madz28 tune does not do it.
Ive always thought it may have something to do with the AIR pump. when the eng. starts cold, the pcm turns on the air pump to heat the cat. conv.s, so I wonder if it has to do with the AIR pump being on. try unplugging it next time you cold start it to see if that makes it go away. but beready to have the code cleared cause it'll prolly turn on the check eng. light.
chris
Old Oct 3, 2004 | 10:16 PM
ChrisS95TA's Avatar
I can clear the codes with my autoxray scanner so I am gonna try that at next cold start. Thnx for the tip, good to know it is just the exhaust
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 11:59 AM
captcorvette
Mar 7, 2015 12:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
