Exhaust ?
Old Sep 1, 2004 | 10:50 AM
Z-RATED94's Avatar
Exhaust ?
Does anyone have an idea on how much HP might be gained on a full bolt on car with LE heads and a small cam by taking the cat off? I have 1 5/8 shortie headers with a cat that I believe is choking the motor. I've heard the cat only cost about 5 to 7 HP on a stock set-up. What about my set-up? Bad enough I'm running shorties, should I lose the cat?
Old Sep 1, 2004 | 03:21 PM
unvc92camarors's Avatar
Re: Exhaust ?
i say get a highflow
i've never really liked the sound of a no cat car and a high flow keeps you legal
Old Sep 1, 2004 | 04:19 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: Exhaust ?
http://www.thunderracing.com/catalog...p&vid=4&pcid=8
I know its expensive but it will flow almost as well as a "hollowed out" cat or a straight pipe and it keeps you legal and i like the sound.... I'm gettin one put in soon because i also think that my stock cat is slowing me down a good 5rwhp or so...
Chris
Old Sep 1, 2004 | 04:24 PM
WS Sick's Avatar
Re: Exhaust ?
As power increases, the restriction the stock cat poses increases as well, If youre in a state that requires it a good high high flow cat will really benefit you, if not no reason to keep it.
Old Sep 1, 2004 | 06:21 PM
MTL_Z28's Avatar
Re: Exhaust ?
Although replacing your cat with a straightpipe on a stock car will not do that much in terms of performance, it will definitely help if you suspect that your cat is clogged. You won't make more power, but you will make all the power that you're supposed to be, and that your car seems to be lacking if this is the case. btw the noise difference is minimal when going from cat to straight through pipe, many people I know couldn't tell the difference. Only a bit louder than stock since you still retain the muffler. If you have strict emissions laws where you live then definitely invest in a high flow cat like WS Sick said, especially since you will be running ported heads and a cam.
Old Sep 1, 2004 | 11:13 PM
Smokn '94 Z's Avatar
Lightbulb Re: Exhaust ?
I lose .2 tenths with my FLP high Flow cats and a couple MPH as opposed to the FLP offroads that I run all the time...
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
