EXACT differences between my '95 LT1 and the Vette LT1?
Old Mar 18, 2004 | 07:32 PM
warwickbass's Avatar
Besides the 25 more horsepower difference.
Old Mar 18, 2004 | 07:57 PM
No one knows yet? Heh, neither do I.
1994TransAm's Avatar
the TB on the camaro is 48mm... vette is 52.
the oil pan is different on both cars...exhaust manifolds are also different.
Old Mar 18, 2004 | 07:59 PM
will62085's Avatar
vettes are 4 bolt mains
Old Mar 18, 2004 | 08:00 PM
GreenDemon's Avatar
External? Intake & Exhaust...
Internal? 2 bolt vs. 4 bolt.
I think that about sums it up.
The difference is pretty neglidgible.
Hmm...Would it be a good idea to "upgrade" my LT1 to the actually Vette engine? And how much would that cost? Thanks.
Old Mar 18, 2004 | 08:04 PM
CamaroSS30thAnn's Avatar
mostly cam and the free-er flowing exhaust
Old Mar 18, 2004 | 08:09 PM
GreenDemon's Avatar
Cams are for the most part the same, although there are some variations by year.
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Mar 18, 2004 | 08:21 PM
RedHottG2's Avatar
Just do exhaust modds such as headers and a good cat back and put in a nice cam and that alon will outweigh the Vette motor by far. I see no need to upgrade to a Vette motor, the only advantage would be 4 bolt mains IMO
Old Mar 18, 2004 | 08:23 PM
That's true. What stainless steel catback you recommend?
Old Mar 18, 2004 | 08:29 PM
RedHottG2's Avatar
Magnaflow is the cheapest I beleave...Corsa, Borla and GMMG are expensive as far as stainless goes. Hooker is aluminized but it is a good value and sounds and flows great.
Old Mar 18, 2004 | 08:33 PM
Magnaflow is the cheapest I beleave...Corsa and GMMG are expensive as far as stainless goes. Hooker is aluminized but it is a good value and sounds and flows great.
I'll probably just get Magnaflow. I haven't been able to decide. What kind of gain can I expect? Like 20 crank hp and 10 rwhp?
Old Mar 18, 2004 | 08:43 PM
RedHottG2's Avatar
You'll see about a 10rwhp with full exhaust.
Old Mar 19, 2004 | 08:53 AM
stereomandan's Avatar
When you say full exhaust, you must be only talking about the cat-back.
If you do the real full exhaust (Headers and catback), you are looking at 25-35 rwhp.
Dan
Old Mar 19, 2004 | 11:23 AM
rskrause's Avatar
Moderator
Are you sure about the TB? They look the same to me, though I never measured.
As far as internal engine components: cam and the 4-bolt mains are the only differences that I am aware of. The cam differs by 1 or 2 degrees depending on the year. I have the specs somewhere if anyone really wants to know. The rated hp difference is part hype and part real. The real difference is primarily due to the better exhaust and intake system on the 'vette. The cam may account for a couple of hp at most.
Rich Krause
