EWP install - an idea?
Old May 22, 2008 | 08:38 PM
Nitelite's Avatar
Any of you who have put an EWP in for a daily driver, did you ever try wiring in a sort of "dummy" light that you put in the car to warn you of a failure? I was thinking of it today, and thought maybe I can use the low antifreeze sensor plug as a "dummy" ? My sensor has long gone and I just unplugged it to take out the light, but is there a way to wire it up with the WP to signal the light to go off - in case of pump failure?
Just an idea, figured it might work if I wired it properly, and if it's doable... exactly how to wire it up?
Oh btw, installing a CSR pump with a painless wp install kit that I got from summit.
Thanks!
Old May 22, 2008 | 09:15 PM
97HawkLT1's Avatar
That is an interesting idea. I would like to know as well. I will look in to it and let you know what I find.
Old May 22, 2008 | 09:18 PM
Stl94LT1's Avatar
Old May 22, 2008 | 09:37 PM
SS RRR's Avatar
There's also someone I think on the Impala forums who has a "watchdog" system for sale?
Old May 23, 2008 | 12:47 PM
NJ-LE's Avatar
Smile
Or you could put a (3/8 MNPT) "water temp idiot light" switch in the unused cooling water port in the passenger side cylinder head and use it to provide the ground that can energize a 12 vdc buzzer from Radio Shack and a light too, if desired. Speaking for myself, I do look at my gauges but it only takes a minute to drive for a mile or more with the motor warmed up and a failed water pump at highway speeds. I don't want that experience, now I have a buzzer to alert me if the water temp gets too high.
warmeck
Mar 22, 2015 10:28 AM
maybe2fast
Feb 5, 2015 05:14 AM
Jlo
Feb 3, 2015 09:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
