EVERYTHING in the ignition has been replaced still missing
Old Mar 20, 2006 | 10:56 PM
  #16
speed_demon24's Avatar
Re: EVERYTHING in the ignition has been replaced still missing
Originally Posted by Javier97Z28
Flashing SES is probably due to your crank position sensor still being enabled and detecting the cam lope as a misfire.
I still have my 97 PCM for my A4 if you want to try it out, i'm a bit far from ya tho. it only has a stock tune tho
I've had this cam for about a year now, and it's never done that, and the flashing light happens when I'm driving, not at idle.
Old Mar 20, 2006 | 10:59 PM
  #17
Originally Posted by roguedriver
Have you checked for vac leaks yet? All the intake manifold vac lines and also make sure your EGR is not stuck open or not functioning improperly. You also said it got worse after a set of plugs. Is it possible you may have cracked a plug while putting them in? Been there done that. How does it idle? Is it worse under load vs cruise? Does it do it at any speed/rpm? Just looking for more info.
Ken R.
I dropped a plug a few times before I finally got it in, but I looked at it very close and I didn't see any cracks. And I started up my car in the pitch black, and there is no signs of arcing at at all. I don't have the ERG on anymore, and the I'm pretty sure there's no vacume leaks. It is a lot worse under load, but its starting to backfire during cruising now too. It does it at any speed, from idle to whatever, and it still does it at WOT too.
Old Mar 20, 2006 | 11:00 PM
  #18
Originally Posted by turbo_Z
Do you still have the original OBD2 computer or did you go OBD1?
OBD2
Old Mar 20, 2006 | 11:04 PM
  #19
Javier97Z28's Avatar
Moderator
Have you checked fuel pressure under load as well as at idle?
Old Mar 20, 2006 | 11:06 PM
  #20
Yep, both are fine, if anything its a tad on the high side, around 45-47 at idle with the vacume line connected, and 50 with it disconnected.
Old Mar 20, 2006 | 11:11 PM
  #21
Moderator
I think I've asked this before, but false knock pulling timing?
Old Mar 20, 2006 | 11:14 PM
  #22
Sometimes it gets KR, sometimes it doesn't, missed just as bad with KR as it does without.
Old Mar 20, 2006 | 11:18 PM
  #23
Moderator
I guess some issue with the PCM is the last thing that can be tried really..
If all the ignition checks out
If fuel pressure at WOT, idle, and everywhere b/w is OK
If injectors check out OK
If valve lash is OK
Yeesh..
Old Mar 20, 2006 | 11:21 PM
  #24
If valve lash is OK
Yeesh..
Valve lash was done 2 months ago, ignition is all good, fuel pressure was tested, and the injectors were tested at a shop too. I guess I can have brian send me another pcm and see if that helps.
Old Mar 20, 2006 | 11:37 PM
  #25
BA383TA's Avatar
You may have marginal or faulty sensors, MAP/inlet air temp/coolant temp. Those can screw up your air/fuel ratio's.
Old Mar 20, 2006 | 11:38 PM
  #26
All of those look fine on the scanmaster...
Old Mar 21, 2006 | 02:40 AM
  #27
1racerdude's Avatar
As was said earlier gap the plugs to .035 and try it.It won't hurt a thing. Ya might want to try some plugs with no exotic metal also, as the caps tend to fall off of them and create a BIG gap. Don't cost anything but some time either.
Look at the plugs when ya got them out and check the resistor in each plug with an ohm meter.
Old Mar 21, 2006 | 03:50 AM
  #28
Jon A's Avatar
PCM's can and do go bad and often they display symptoms just like you're experiencing. If you follow the factory service manual for symptoms like this, in almost every section it'll say replace this, replace that, test this, test that.....and if none of that works replace the PCM.
You are likely at that point.
Old Mar 21, 2006 | 07:01 AM
  #29
97FormulaWS-6's Avatar
Check your sensor wiring. I has a intermittent miss for 2 seasons that was at times so bad that the car would barely run. After spending over $1200 on ignition parts and ungodly amounts of hours trying to find it; I found that someone had used an un-sealed blue-butt connector to splice the coolant temp sensor for the PCM and buried it in the wire loom. The wires were soo corroded that when I finally found it, no lie, there was one strand of wire still crimped into it.
It's little things like that, that can cause the headaches like you're dealing with.
Old Mar 21, 2006 | 07:43 AM
  #30
jbsupra89t's Avatar
Like was mentioned check the PCM... almost same thing occurred with my friend's car. Good luck, enjoying thsoe ZR1s?
-J
