Everyone get in and post your oil pressure!!!
Old Jan 27, 2006 | 09:18 PM
Wckd94Z's Avatar
Ok the stock gauge probably blows, but I'm curious what you guys are reading at idle. Mine is sitting at the first line up from 0, I don't know what pressure that is, but is that acceptable for a 78k mile car with mobil 1 5w-30 at an 800 rpm idle?
Please post:
Oil type
Idle RPM
Gauge level (i guess line on the gauge?)
Pressure if you have a real gauge
I'm planning on getting a dual gauge pod once I get nitrous on the car, probably nitrous and fuel pressure gauges there. And does anyone make a plate that goes over the storage place next to the cigarette lighter? I'd like to maybe stick a oil pressure and water temp there. Any suggestions?
I know this is a weird mixed up thread, but thanks
Old Jan 27, 2006 | 09:26 PM
RE AND CHERYL's Avatar
Re: Everyone get in and post your oil pressure!!!
Mobil 5000 10w/40
stock idle speed
just above 1st line at idle when warm and justa bove middle line at cruise when warm.
Old Jan 27, 2006 | 09:31 PM
Demon's Camaro's Avatar
For one yes that is fine at idle. Mine is at 0 after about 10 minutes(did I mention bearings are gone ) I should put a 450 shot on it and see how that works out for my car.
Old Jan 27, 2006 | 09:35 PM
2000GTP's Avatar
18-20psi @ idle w/ Mobil 1 synthetic 5W30.
Old Jan 27, 2006 | 10:11 PM
StephenDeli22's Avatar
Quaker State 5W-30
Idles at 1000 rpm
My pressure at idle is at or just below the first bar up, so I would say like 18-20 PSI also.
Old Jan 27, 2006 | 10:19 PM
RacingTiger04's Avatar
151k miles idle warm at around 600 and first mark on the bar or slightly above usually castrol syntec 10-30... with synthetic mobil 1 10-30 its usually just a hair below the line in same conditions.
Old Jan 27, 2006 | 10:24 PM
earnhardtJR's Avatar
At 850 rpm idle after the engine is warm, mine is about 27 psi (1/3 of the way between the first and second) and is about 45 psi off idle. This is with 119k on the engine and with Mobil 1 5W30.
Dnlracin's Avatar
We are using castrol high milage 10-30 the car does have a 144,000 on the clock at idle(900 rpm) it will read 20 lbs and crusin around it will read 40 lbs all on the stock gauge
Old Jan 27, 2006 | 11:06 PM
3400Camaro's Avatar
95 Z28 with Quaker 5w30 and 179,000 runs right on or slightly above the first mark up and right in the middle cruising.
Old Jan 27, 2006 | 11:16 PM
Ray86IROC's Avatar
At a warm idle (with an auto, it's like 600 rpm or something) mine is around 18 psi, just below the first line. Crusing around 2k rpm it's halfway between the first and middle marks, around 30 psi I guess. WOT hits about 40, never really any higher. On 10w-30 Dino oil, Havoline so far. 141k miles
If I've been sitting in traffic and my engine is running 215+ degrees and the oil is good and hot it might idle more like 15 psi or so...
I haven't actually measured it so this is assuming the stock gauge is both accurate and fairly linear in it's readings...
Old Jan 27, 2006 | 11:22 PM
marshall93z's Avatar
Havoline 20W-50
270,000 miles and 30 psi @ idle hot.
Old Jan 27, 2006 | 11:34 PM
HardcoreRM125's Avatar
16,700 Origional Miles
40+ PSI @ cold idle.
Hot Idle 30ish
WOT ??? I glance at it to make sure its not low, but dont realy pay attnetion to what it peaks at?
Sotck Idle on a M6 car.
Old Jan 27, 2006 | 11:39 PM
Blackthunder50's Avatar
Valvoline 5W-30 synthetic
warm idle is 30 psi@950RPM
Cruising 2000-3000 its about 45-50 psi
WOT its a little over the third line(60 psi)
During my morning commute to temple its 60 psi the whole way.Note its only 20 some degrees during the commute and the car sits outside.
Old Jan 27, 2006 | 11:43 PM
Cmr0z28's Avatar
20psi hot idle, 45psi driving. Castrol GTX 5w30
Old Jan 28, 2006 | 12:24 AM
Wckd94Z's Avatar
wow guys great response thanks a lot!
I was worried about pressure at idle, mine sits right on the 1st line at hot idle with mobil 1 5w-30, after my cam swap. I remember it was just a touch above it before the swap when I used castrol gtx 10w-30. So I guess I'm pretty good for 78k miles?
