Every cam bearing destroyed...
Old Nov 10, 2006 | 01:11 PM
wrd1972's Avatar
Just pulled them and every one is toast, the front bearing more so than the others.
I have always changed the oil and a nvery near regular basis plus I have been running Mobil 1 synthetic.
Why has this happened in just 78K miles. I did have some GM guide plates wear bad as a result of the wrong length push rods so that is the only case of metal shaving I am aware of. The rocker geometry was offset to the exhaust side a good bit. I figured the filter would catch most of that but maybe not.
The #1 rod bearings were real bad but the rest of the rods and mains showed wear but were not ruined.
I drive the car hard but not an abusive level. Is there a certain driving style that takes its toll on berings? Could thos worn guide plates have done this? What the hell?
Old Nov 10, 2006 | 01:16 PM
MeanGreen97Z's Avatar
Having the valve train geometry incorrect probably put extra strain on the bearings.
Old Nov 10, 2006 | 01:51 PM
wrd1972's Avatar
I guess this is possible, I would guess that there was less than 3K on the bad geometry. Could very well be.
Old Nov 10, 2006 | 05:05 PM
How far off were the pushrods?
Old Nov 10, 2006 | 05:13 PM
wrd1972's Avatar
In order to achieve a dead center narrow pattern I had to go from the stock 7.200" to 7.050". It was a big jump and the bad pattern was clearly low to the exhaust side. I have obviously have the right size pushrod cause I have zero guide plate wear now.
Old Nov 10, 2006 | 05:29 PM
Ya .15" is a big jump and possibly put added stress on the bearings since the valve train was in a bind at all times.
Old Nov 10, 2006 | 05:32 PM
wrd1972's Avatar
I really hope you nailed it, cause now I will have beehives and the LE1.5 cam going in.
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
