Ever see an optispark full of oil?
Old Apr 4, 2008 | 07:48 PM
ToocoolZ28's Avatar
I just replaced my opti because the car was running like crap the last few months. When I took the old one off and layed it down a BUNCH of oil ran out the hole where the electrical plug goes in, I mean like a cup of oil ran out. How can oil get in there??
Ron
Old Apr 4, 2008 | 08:03 PM
slowZ's Avatar
yeah. when i replaced mine the last time oil got in there. it was due to the splined shaft(94) had a grove wore in it from the old seals and i didnt notice. so when i replaced the new seals they let oil leak in.
Old Apr 4, 2008 | 08:09 PM
96capricemgr's Avatar
On a 95 my best guess woul;d be a combination of leaking oil seal in the timing cover and a vacuum leak at the back of the opti allowing it to suck the oil in. Certainly an odd problem, every one I have ever pulled has been bone dry, even the ones that were covered in oil from leaks at the WP seal.
Old Apr 4, 2008 | 08:18 PM
ToocoolZ28's Avatar
Well this thing did have a leak at the front, everything was covered in oil. Both O-rings on the opti shaft were completely gone.
Hopefully it will run better if I ever get it together again.
Ron
Old Apr 4, 2008 | 11:10 PM
If it was in the well where the electrical connection is (and not inside the opti), it might be just from a poor seal on that connector (and your oil leak, of course). I would be taking a look at the harness connector.
Old Apr 5, 2008 | 02:03 AM
Green96Z's Avatar
I have a leak on the front cover (still trying to track it down), and I've noticed the crank hub slings it up onto the opti. Last opti I opened one up was drenched in oil from that.
Old Apr 5, 2008 | 02:12 AM
red1984's Avatar
this is waht mine looked like when I took it apart
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
