evaporative emissions ?
Old Mar 14, 2008 | 01:37 PM
texastransam96's Avatar
is there any way to delete the evaportaive emisison system without having the gas smell outside of the car? say by routing the vent into the intake tract before the throttle body so the gases go into the intake? i was wanting to get rid of the sensors to kind of clean up the engine bay a bit, but if there isnt any way around it i am going to keep them? anyone have any ways of getting rid of this ?
Old Mar 14, 2008 | 02:00 PM
That's exactly what the EVAP system does - vents the system into the intake. But the PCM controls when it happens, and takes that into account in how it fuels the engine. There are no sensors. There's some tubing and a single solenoid. Why not move the solenoid where you can't see it? If you remove the solenoid, you get a code, which you can eliminate with a resistor or have "programmed out".
Old Mar 14, 2008 | 02:06 PM
yeah i am going to have it tuned out, when i have the computer redone. and rather than go through the solenoid i was just going to route it into the intake tract under the intake tubing, where it cant really be seen..... basically what i was asking is would this hurt anything ? i saw where they have added a filter after the carbon canister, but have heard it leaves a pretty nasty exhaust smell..
Old Mar 14, 2008 | 02:26 PM
When the canister is empty, you'll be pulling in air = bypassing the MAF. So you would have to put it before the MAF. But when it has fuel vapor in it, its going to throw off the engine's fuel calculations. Probably not a big error, but the system is the way it is to prevent these errors.
And, you will need a vacuum relief on the tank or somewhere in the vent system, since you will be pulling a vacuum at all times on the tank. Put a vacuum on the fuel tank, and you run the risk of the fuel flashing to vapor.
Old Mar 14, 2008 | 02:34 PM
reimer96z's Avatar
my evap system went out and was throwing a trouble code so i just had it tuned out but left the actual system alone..is this harmful to my car?
Old Mar 14, 2008 | 02:48 PM
that will work thanks injuneer. i amk not to familiar with the evap. soudns like more trouble than its worth. i will just leave it.
reimer96z, i would think the solenoid would be closed if its tuned out, and wouldnt vent properly, but i am not sure...-
Old Mar 14, 2008 | 08:24 PM
reimer96z's Avatar
ya when i take of the cap to get gas i can hear alot of pressure being released... does anyone know if deleting the evap with a tune but not actually removing the system is hurting anything??
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
tbyrne
Jul 2, 2002 05:37 PM
