EVAP Solenoid Valve Pipe Assembly 10105324 (to TB)
Old Mar 3, 2011 | 03:40 PM
lightskindwonder's Avatar
Mine has cracked in two and is currently held together in several locations with electrical tape. I've called a local dealership, and according to them, the part has been discontinued and not available anywhere. Any ideas of how I can fabricate one since the two ends of the tube are different sizes? What are the effects if I plug the connectors or remove the evap solenoid completely and tune the system out?
Old Mar 3, 2011 | 04:43 PM
Re: EVAP Solenoid Valve Pipe Assembly 10105324 (to TB)
You should be able to get some hard tubing at the parts store and some rubber adapters to go with it. Try a right angle spark plug boot on the TB end. You could always use some regular vacuum hose, too.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Mar 23, 2015 08:06 AM
Jazsun
Dec 29, 2014 12:14 PM
kclarson
Aug 22, 2002 04:04 PM
