EVAP line Connection???????
Old Jan 5, 2006 | 12:28 PM
Deenasty's Avatar
I just changed my charcoal canister because it was saturated in fuel. Upon removal, I found the middle line (fresh air inlet) connected to the canister, but not connected to anything on the other end. Is this the way it is suppose to be, or does it actually connect to something? Thanks guys!
Old Jan 5, 2006 | 12:55 PM
OBE1 95Z28's Avatar
Re: EVAP line Connection???????
From Shoebox's site:
http://shbox.com/1/evap_system.jpg
Old Jan 5, 2006 | 01:19 PM
Deenasty's Avatar
I have that diagram as well, but notice how the lines get confusing.. That diagram is not the best. Also, notice the evap canisters middle connection does not have a line, and mine does. This might be for a 93 model...
Old Jan 5, 2006 | 06:31 PM
matLT1's Avatar
I just got done removing my EVAP from my car and the middle line wasn't attached to anything on my car either. I believe that line functions to let air into the canister for when the fuel vapors are sucked up stream to the throttle body. That would make sense seeing that if you wanted to "flush" the canister, one would have to have some sort of air flow through it to get all of the fuel vapors out.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Strick
May 26, 2015 11:41 AM
Jazsun
Dec 29, 2014 12:14 PM
