EVAP (code P1441)
Old Mar 29, 2004 | 09:49 PM
Jeremy_30th's Avatar
EVAP (code P1441)
Ok I did a search and want to double check if want i'm doing is correct. First I pulled the vaccum line off the valve to verify if there was vaccum (continous open) and there was so this tells me the valve is bad. Should I automaticly rule out the flow sensor because there was vaccum at idle (valve stuck open)? I guess what I really need to know is when is this valve suppose to open ? And then I can determine if its the flow sensor or actually the valve.. Thanks
Old Mar 29, 2004 | 10:16 PM
The round vacuum switch merely senses the flow. It is just there to tattle-tale on the system (required by OBD-II).
The EVAP solenoid is only energized when the PCM tells it to be. It is usually during part throttle conditions.
Make sure that the hoses to the solenoid are not reversed. Upper hose to the TB and lower hose to the vacuum switch. (see your emissions sticker on the radiator cover)
If that is ok and you still detect vacuum through the solenoid at idle, remove the electrical connector and see if the vacuum goes away. If it does, then the solenoid is stuck open.
Old Mar 29, 2004 | 10:35 PM
Shoebox ...Guess after my heads, intake ect. install I hooked them up backwards the top hose was to the flow sensor and the bottom went to the TB.. Darn OBD2 took about 2 months to tell me I screwed up although I drive it on weekends.. Thank you Sir...
Old Mar 29, 2004 | 10:41 PM
S.J.S.'s Avatar
Hey Shoe.... remember I asked about the EVAP hose a couple days ago??? Would that effect anything (speed wise) if I was running it on the track with the hose disconnected from the solenoid???
Strick
May 26, 2015 11:41 AM
Jazsun
Dec 29, 2014 12:14 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
