errr bent push rod!!!!
Old Mar 1, 2005 | 09:28 PM
Jameslt1TA's Avatar
Angry errr bent push rod!!!!
Well finally figured out why my engine isnt running right. I took off pass valve cover and only 2 pushrods are still in there hole!!!!!! I got a magnet and fished two out of the lifter valley and one was bent, does this mean that a valve hit a piston??? Also ive never really dealt with roller rockers but for some reason i think that i was not sent self alighning like i ordered!!!!!!!!!!!
Old Mar 1, 2005 | 09:45 PM
3gc's Avatar
3gc
Re: errr bent push rod!!!!
I had a similar problem with my old L98. I forgot to tighten the set screw on one of the poly locks, it backed off a bit and the pushrod fell out and actually broke in 2 spots. Make sure you tightened them.
Old Mar 1, 2005 | 09:48 PM
Jameslt1TA's Avatar
I just looked at some pics of non self aligning rrs and the look like mine. I think because there was no plate under them it raised the lift and a f*cking valve hit a piston. I dont know im just really mad right now.
Old Mar 1, 2005 | 09:57 PM
3gc's Avatar
3gc
The difference between rockers wouldn't change the lift. If your heads were machined for guide plates and you didn't use any then it probably would. Atleast, as far as i know. I'd get the correct rockers, replace the bent pushrod and run a compression check.
Old Mar 1, 2005 | 10:06 PM
Jameslt1TA's Avatar
You guys think that combination motorsports will just exchange my rrs since they gave me the wrong ones(i think im still not sure what the look like exactly). Im almost scared to take off the other valve cover because i dont want to see more bent pushrods.
Damn i hate working on cars anymore
thanks guys
james
Old Mar 1, 2005 | 10:27 PM
SStrokerAce's Avatar
Look at your rockers and then at the bottom of this page.....
http://www.compcams.com/Technical/Cu...g/HTML/311.asp
Then you will know the if they are SA or NSA.
Bret
Old Mar 1, 2005 | 10:55 PM
Jameslt1TA's Avatar
Checked the rrs, they are self aligning, guess im just a stupid idiot that cant adjust rockers, even with a guide. So do you all think all i need to do is replace the pushrods or did a valve and piston hit?
thanks
james
Old Mar 1, 2005 | 11:01 PM
What kind of PR's where they?
Old Mar 1, 2005 | 11:04 PM
1racerdude's Avatar
thanks
james
You running SA rockers with guide plates??
THAT'S a NO NO.
Old Mar 1, 2005 | 11:08 PM
turbo_Z's Avatar
thanks
james
I bet you just didnt have the RRs locked down or have the valve lash set correctly.. possibly too loose.
THAT'S a NO NO.
I was kind of hoping he isin't doing that.
Old Mar 1, 2005 | 11:13 PM
1racerdude's Avatar
thanks
james
Brent,
That is what it say's,don't know.
Old Mar 2, 2005 | 12:20 AM
trans9_5am's Avatar
I dont think the guide he is talking about here is a guide plate.
Brandon
Old Mar 2, 2005 | 12:34 AM
1racerdude's Avatar
Yea could have been a manual????
Old Mar 2, 2005 | 12:42 AM
trans9_5am's Avatar
Lol thats what i was thinking at first. I also thought he might be referring to the "guide" on the SA rocker. Im gonna stick with my first guess though LOL.....
James - What method did you use when adjusting your rockers?
Brandon
