Eportworks LT1 LE1 Value & Performance
Old Aug 23, 2005 | 06:14 PM
  #16
jchevy's Avatar
Re: Eportworks LT1 LE1 Value & Performance
I have a stock bottom end with just over 100K on it.
Old Aug 24, 2005 | 04:28 PM
  #17
91_RS_LT1's Avatar
My dad was afraid that the motors had alot of aftermarket work done to the bottom end to get the stated power. I didn't think that that was the case, but wanted to be sure. I'm sure that if the work were done, it would increase performance as well as the life of the motor. Might be worth looking into when I do the change...
Another question....
I am pretty sure that LT1's are roller cams, but are they roller rockers as well. If not, where is a good place to get roller rockers?
Old Aug 24, 2005 | 04:36 PM
  #18
Cmr0z28's Avatar
LT1's don't come with roller rockers. Plenty of our supporting vendors sell them. https://www.camaroz28.com/misc/vendorindex/
Old Aug 24, 2005 | 05:55 PM
  #19
Kory 88 Iroc Lt-1's Avatar
I put down 350rwhp/360rwtq With a set of Lloyds old heads (before the stages) I have since upgraded to the LE2 cam and hope to dyno soon. The car is very drivable. Also I'm running a stock shortblock. I believe most Guys are doing that. I spin my motor to 6500 rpms with no problems
Btw do the engine swap. I did mine 3.5 years ago and Love it.
Hope this helps,
Kory
Old Aug 24, 2005 | 07:36 PM
  #20
Robs97Z28's Avatar
Originally Posted by SStrokerAce
Plus the LE packages are designed to work with the LT's
Bret
Well then, you better get busy and make a cam to work with shorties! There are a few of us that have little choice. I just might have to move to a different state (CA). LMAO
Old Aug 24, 2005 | 07:55 PM
  #21
SStrokerAce's Avatar
Someone gets me some good measurements on one so I can figure where they tune differently than the LT's and I might be able too.
Bret
Old Aug 24, 2005 | 08:13 PM
  #22
Robs97Z28's Avatar
I was try to be a smart a$$. I guess you told me. I don't get a choice of the type of header I can use. Since, I am living in cali.
How would I measure the headers? are you looking for tube runner length? or are youlooking for cc volume?
Old Aug 24, 2005 | 09:03 PM
  #23
Runner length of all the pipes would help, from where they meet the head to where they end up in the collector.... bad thing is it's the middle of the pipe that counts not the shortest distance.
Bret
Old Aug 24, 2005 | 09:38 PM
  #24
JoeliusZ28's Avatar
Originally Posted by jchevy
The idle is pretty smooth, sounds pretty similar to a hotcam car.
Here is a short video of my car idling about 1000 rpm
http://mywebpages.comcast.net/jared1181/idlevid.mov
just out of curiosity, does that idle get choppier if you dropped it to say 800 rpm or lower?
Old Aug 24, 2005 | 09:42 PM
  #25
jchevy's Avatar
Yeah, it does a little bit, but not a whole lot.
You can deffinatly tell its cammed, but it is somewhat of a sleeper.
Knowing the specs of the cam, I am really suprised its not a lot more choppy.
Old Aug 24, 2005 | 09:50 PM
  #26
Silvershark's Avatar
I have Lloyd Elliots LE2 heads with a GM847 cam. His portwork is excellent. Click on the link in my signature and go to car parts. There are some pictures of his heads. My car is defiantly streetable with the help of Ion's tuning! I am running 90 octane gas and I just beat a z06 today. I have yet to dyno/get track times.
Defiantly worth the money for the performance and quality of work he does!
Old Aug 25, 2005 | 10:37 AM
  #27
91_RS_LT1's Avatar
Would it be recommended to install roller rockers on the LE1 heads?
Would it be a good idea to throw in a steel crank since I have to have the whole motor out any way?
Old Aug 25, 2005 | 11:04 AM
  #28
Admiral94's Avatar
Roller rockers would benefit any head so the answer is yes.
You don't really need a steel crank at that RPM or power level so just save your money.
Old Aug 25, 2005 | 01:08 PM
  #29
91_RS_LT1's Avatar
I was thinking about in the future maybe adding a supercharger. That is why I was considering a steel crank. But then, with a super, I would need lower compression pistons as well. Money, money, money.
With a 10 pound boost super and the LE1 heads and cam, I would probably be looking at about 450-500 hp right? Or is that an over-estimate?
Old Aug 25, 2005 | 08:15 PM
  #30
hallbilly's Avatar
if it did not break 500rwhp i would be suprised on 10psi... but i do not know that much about boost..
