engine upgrades
Old Apr 13, 2013 | 06:24 PM
Chet1185's Avatar
engine upgrades
I have an lt1 that spun a bearing years ago that was just bored 30 over due to pitted cylinder wall from sitting outside. I just finished rebuilding it with new factory crank, reused the rods, new pistons, stock cam.
Is there anything I can do to the engine before its all together, that is not expensive to add any kind of HP? I built this engine and it is the first time and hopefullyit runs good so I can take the one in the car now and build a nice performance engine.
Posted from Camaroz28.com App for Android
Old Apr 13, 2013 | 07:35 PM
RamAir95TA's Avatar
Re: engine upgrades
It depends on how much money you have to spend and what your timeframe is. Don't expect much performance from a stock rebuild and a stock cam, so I would reconsider your cam choice.
Old Apr 13, 2013 | 07:44 PM
Chet1185's Avatar
Is there a cam that can be used with stock heads, rockers, springs?
Old Apr 13, 2013 | 07:55 PM
parkers Z28's Avatar
Re: engine upgrades
Not really...???... even a stock cam would like a stiffer set of springs
The springs , 1.6rr and guide plates should only set you back 500 bucks
Old Apr 13, 2013 | 07:59 PM
Chet1185's Avatar
So pretty much i'm looking at just doing this one stock then taking the time and money to build the one i'm pulling out of the car?
Old Apr 13, 2013 | 08:41 PM
moparman's Avatar
Re: engine upgrades
A couple bolt ons that work are a cold air induction system and a catback exhaust.
Old Apr 13, 2013 | 08:48 PM
Chet1185's Avatar
Already have headers,slp caI, slp loudmouth
Old Apr 13, 2013 | 08:49 PM
Chet1185's Avatar
What would a higher stall torque converter do? I have a posi 2.73 Torsen unit installed.
Old Apr 14, 2013 | 01:59 AM
Jim D's Avatar
Re: engine upgrades
How about changing to an electric water pump while you have everything apart? Then seal where the hole used to come through to drive it...Just an idea...
Old Apr 14, 2013 | 03:40 AM
Chet1185's Avatar
What's the advantage of the electric pump?
Old Apr 14, 2013 | 06:47 AM
Re: engine upgrades
The stall will make it a little faster off the line but no more horsepower...good bang for the buck !!
I think the stall set me back 700 dollars plus installation .....I would skip the electronic water pump!!!
before you get a stall you will need to know what gears and what cam you plan on using
they all need to work together....most people seem to like something around 3k on a daily driver
Old Apr 14, 2013 | 12:40 PM
KW Baraka's Avatar
Re: engine upgrades
I'd put in steeper gears before I'd do a torque converter....especially with a stock(ish) engine and 2.73 gears.
For your car, I'd consider some 3.42 gears......3.73 gears if you're really feelin' 'giddy'!
Wait until you've built up the other engine before going with the TC.
KW
Old Apr 14, 2013 | 12:49 PM
KW Baraka's Avatar
Re: engine upgrades
1. You can pump coolent through the engine at a constant rate even with the engine turned off. Just have the key turned to accessory mode.
2. Eliminates water pump drag on the engine.....frees up 5-10 HP....depending on who you listen to.
KW
Old Apr 14, 2013 | 01:01 PM
Chet1185's Avatar
Ok, I've decided to just keep this build stock and when I tear the engine out I will slowly start building that and asking for help because I have no clue......
There is a complete 383 Stroker kit on Ebay for #$1600, check it out tell me what you guys think.
Old Apr 14, 2013 | 01:15 PM
RamAir95TA's Avatar
Re: engine upgrades
Typically eBay stroker builds are a BAD idea. I would avoid them like the plague.
