Engine Trouble. (long)
Old May 13, 2009 | 08:27 AM
  #31
lr383's Avatar
I think this it a problem gm has had with the material they are using for this gear like I said before 3 or 4 of my gears wore thin before I caught it .Check shoe box site for a replacement gear part no. that might be a better one but remember to always check it when you have the intake off. watch your oil pressure because you have suck pieces of broken teeth thur your pump! Glad to hear you got it running.
Old May 13, 2009 | 02:49 PM
  #32
JAKEJR's Avatar
I've experienced this THREE times; all three on different engines using different camshafts. One was a 355 L98, another a 415 L98 and the final one was my 96 LT1 which only lasted about 2 thousand miles.
All three were new and were GM gears and two were even a GM melonized gears. I used moly-lube on all three and even used a tooth brush to get the lube down into the teeth.
The common thread in all three was HV oil pumps; but NOT the same oil pump. All three pumps were different and each was installed new. One Melling (10555) and two were Moroso pumps (forgot the #s); but the Moroso pumps had the anti-cavitation slots, etc.
I firmly believe it's the HV pumps that are killing the gears.
My concern now is the LT1 setup. On the L98 engines, the engine would shut off when the distributor gear died, but not so with the LT1.
Since the LT1 Opti is at the front of the engine, the engine will continue running even after the stub shaft gear fails. Engine will run with NO OIL PRESSURE.
I'm wondering if anyone has moved to installing an oil pressure switch that will shut down the engine when oil pressure drops to below a certain amount. This would save the engine bearings should the dash warning light not work or not been noticed.
Thanks,
Jake
West Point ROCKS!
Old May 13, 2009 | 03:48 PM
  #33
lr383's Avatar
Good point! this would solve a lot of the problem of not watching the gauge every min!!! Mine ran for 3 mins for I look down at the dash.
Old May 13, 2009 | 10:26 PM
  #34
BCdawg57's Avatar
Yeah, that would be a good idea to have a fail safe in there. How could that be done?
Old May 14, 2009 | 12:12 PM
  #35
JAKEJR's Avatar
I found a switch in one of the catalogs (JEGS or SUMMIT) a while back that shuts down the engine when oil pressure drops below a certain pressure.
I can't recall which mag it was or any other features. I'm going to look through the two catalogs I have and see if I can find it. When I come up with something, I'll post it.
Jake
West Point ROCKS!
Old May 14, 2009 | 12:26 PM
  #36
lr383's Avatar
Jake
West Point ROCKS!
Kinda like no2 switch we use on dry system. when it get below 50 pd`s it shut off the system. post it if you come up with something! thanks.
Old May 14, 2009 | 12:50 PM
  #37
JAKEJR's Avatar
Here's one I found.
http://store.summitracing.com/partde...5&autoview=sku
Jake
West Point ROCKS!
Old May 14, 2009 | 11:52 PM
  #38
Hal Fisher's Avatar
Looks like a good idea but having it cut gas all of a sudden sounds bad. Maybe just hook it to something else that you may notice like the mileage/trip light on the dash? If someone could draw up a circuit that flashes those it would be even better. Or, hook it to the Check Engine light using the optional light connection.
I think I found the T needed for this: http://store.summitracing.com/egnsea...DS=1&N=700+115
Hal
Old May 16, 2009 | 05:22 PM
  #39
JAKEJR's Avatar
Anyone know where you can get the 1/8" pipe tee to install this? It needs to have two male and one female ends I believe.
I think I found it: http://store.summitracing.com/egnsea...DS=1&N=700+115
Hal
ACE hardware carries all those type fittings in different diameters, lengths and threads.
Jake
West Point ROCKS!
A's 91 Z28
Jan 11, 2015 10:58 AM
Snoman73
Nov 17, 2014 07:22 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
centric
Aug 15, 2002 09:04 PM
