engine ticking :(
Old Jul 6, 2008 | 09:15 AM
Ta4life's Avatar
engine ticking..with video :(
had headers on for 150 miles with it running good and last 50 miles it was getting bad gas millage and made this noise 15 miles.
after a oil change / warm up it does not make it at idle anymore...
View Video on FQuick
lifter....or rod knock?
Old Jul 6, 2008 | 09:19 AM
joeSS97's Avatar
Sounds to me like an exhaust leak.That would explain the poor mileage too.
Old Jul 6, 2008 | 09:22 AM
Ta4life's Avatar
that was my guess first. but it sounds more solid than sucking air.
i think ill loosen the header bolts and reseat the gaskets to ensure myself
Old Jul 6, 2008 | 09:40 AM
joeSS97's Avatar
If you are going to do that you might as well pull the gaskets an look for signs of a leak. What gasket did you use?
Old Jul 6, 2008 | 09:44 AM
Ta4life's Avatar
it was the normal gasket material.. they came with my headers. was not steel ones like OEM.
Old Jul 6, 2008 | 09:52 AM
joeSS97's Avatar
Get a better quality gasket. Are they Kooks headers?
Old Jul 6, 2008 | 10:14 AM
LeeCTS-V's Avatar
Check the dipstick as well. I've had mine touch the header and make that noise as well.
-- Lee
Old Jul 6, 2008 | 10:17 AM
95z28man's Avatar
I can tell you that I had an exhaust leak and it sounded identical to that. I could of sworn it was something else because sometimes it really does sound like it's rods or rocker or something more serious, but it's just a leak. I would definately try that before you dig too deep.
Old Jul 6, 2008 | 10:37 AM
LearJet's Avatar
Sounds like one of your rocker arms came loose to me. My car sounded just like that when I bent a pushrod. I would pull the valve covers off and have a look. you could use a stethoscope too pinpoint the noise, if you don't have one just use a long screwdriver and hold the handle to your ear.
Old Jul 6, 2008 | 10:39 AM
Ta4life's Avatar
i pulled one valve cover last night and everything seems good in there. im taking headers off and reseating them to see if that is my problem.
Old Jul 6, 2008 | 05:51 PM
Ta4life's Avatar
still looks like something with motor. headers made no difference
Old Jul 6, 2008 | 07:46 PM
95z28man's Avatar
Definately a loose rocker or something up with a rod. Avoid running it too much until it's fixed.
Old Jul 6, 2008 | 09:23 PM
maverickmk's Avatar
check the trans - the inspection cover and the bolts on the converter/flex plate see if any of those are loose - just a thought
Old Jul 6, 2008 | 10:19 PM
OH95Z28
Guest
Posts: n/a
rocker
I vote rocker too. u need to take the valve covers off while the car is running and see
Fatdog2
Feb 12, 2015 12:24 PM
importkiller94
Jan 17, 2015 09:03 PM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
smokin25th
Jan 1, 2015 09:06 AM
Zone
Jul 29, 2002 07:43 PM
