Engine Temp. Just below half ?
Old Aug 19, 2009 | 07:06 AM
stephenpen's Avatar
My engine is running just below half way on the highway. Where should it sit. When I first got the car it ran just above a quarter on the gauge and never changed.
Old Aug 19, 2009 | 07:44 AM
dangalla's Avatar
usually these cars run pretty hot. like around 3/4 gauge stock
did you do anything to make this change you speak of? i would most likely suspect a bad temp sending unit - to the gauge not the pcm.
Old Aug 19, 2009 | 08:33 AM
rngilliland's Avatar
Mine runs just above the 1/4 mark with the stock thermostat. Make sure you aren't low on coolant and that nothing is blocking air flow to the radiator. A damaged air dam can also affect air flow to the radiator. If those are okay I would change the thermostat. It could be a bad sensor or gauge. If you have or can borrow a scanner you can see what the pcm sensor is showing and how it compares to your gauge.
Old Aug 19, 2009 | 08:38 AM
6SpdLT1Z's Avatar
That's not bad, mine runs ~ 190-210* with the fans tuned to kick on a bit earlier than stock. Check for leaves under the radiator, ensure your thermostat isn't stuck open, etc.
Old Aug 19, 2009 | 09:06 AM
dangalla's Avatar
this is not normal at all and i would suspect that your car has a problem as well
Old Aug 19, 2009 | 09:29 AM
caldercay's Avatar
I own 2 '95 Z's and both gauges hover just above the 1/4 mark.
The bottom mark is 160* and the top-most 260*, which gives us
a 100 degree spread; the 1/2 way mark would be 210* and the
1/4 mark would be 185*. The only time the gauge approaches
the 1/2 mark is when in stop-n-go traffic - and that's with our
95+ degree / 90% humidity days in southern Texas.
Old Aug 19, 2009 | 10:29 AM
johnnyb's Avatar
why would his car have a problem if it runs cool? I think the problem would be your car running 3/4 of the way. my le3 355 runs a little under the 1/2 mark
Old Aug 19, 2009 | 10:37 AM
stephenpen's Avatar
I just put a front lip on the other day and ever since I've noticed the gauge reading higher. I was not going to worry about it if other people run around the same temp with no problems. Before the lip my gauge sat around 1/4. I have a extra fan sitting around maybe I might mount it in front of the rad.
Old Aug 19, 2009 | 10:43 AM
You need a lower air dam to compensate for blocking the stock airflow to the radiator.
Old Aug 19, 2009 | 10:47 AM
dangalla's Avatar
my car runs around 1/4 also - but that is with a lower thermostat and tuning to turn the fans on sooner.
if his car was always reading one thing and suddenly reading another there might be a problem. i dont think his car has a problem but rather the gauge is not indicating the correct temperature
and a stock car with a system operating correctly should be considerably warmer, which is why i stated to the other person his car might have a problem also being that he stated his was stock
i dont see what is so funny about his gauges giving him an incorrect reading
Old Aug 19, 2009 | 10:57 AM
stephenpen's Avatar
I already installed a air dam that is 1.5 inches longer and it did not make much of a difference. I also have a 160 thermostat and my fans come on early. I have my nitrous system mounted under the rad cover so I'm going to move that just incase its blocking some of the air flow.
Old Aug 19, 2009 | 02:14 PM
I've owned the car since new and it has always run just above the 1/4 mark on the highway. That should be around 195 degrees the way my gauge is marked. Seems about right to me for a 180 degree thermostat.
Old Aug 19, 2009 | 02:26 PM
ThreeHonks's Avatar
The stock gauge is never really a good way to tell your EXACT temperature. Only thing its good for is to show whether the engine is either really hot or cold.
Old Aug 19, 2009 | 02:38 PM
'94 Bad A Z28's Avatar
My car runs below the 1/4 mark... scanner shows ~175-184*
Old Aug 19, 2009 | 02:39 PM
There is nothing wrong with the gauge being at the half way mark though.
