Engine Swap Question
Then there's the issue of the LS1 running a dead end fuel system at 58psi, with the regulator back in the tank, vs. the LT1's recirculated system, at 43.5psi, with the regulator on the fuel rails. This could be resolved by getting the fuel rails from a 97 Corvette LS1, which did have a recirculated system, and an adjustable FPR.
Probably want front springs matched to the all-aluminum LS1's weight.
The list goes on and on.
Here are a couple of links that might get you some info you are wanting:
http://www.ls1tech.com/forums/lt1-lt...-ls1-swap.html
http://www.ls1tech.com/forums/conver...body-help.html
There might be others, but I haven't checked in a while. Go to the "hybrids" section of the LS1tech.com message board
Thanks David for the information. This does answer some of my questions I had on this subject. I don't know why I thought that this could be done with engine, wiring harness, and of course ECU. That would be too easy. hehehe
squirrels
Jul 13, 2002 01:58 AM
