Engine swap..please help
Old May 25, 2007 | 05:14 PM
Carlos26's Avatar
I have a 1997 Z28, i'm swaping the engine with a lower mileage 1995 trans am Lt1, do i need to change harness and cpu? are they the same, some sensors maybe? what about the obdI and obdII thing?
Old May 25, 2007 | 06:20 PM
96ZCamaro's Avatar
If you are just swaping the engines. Your pcm will work just fine along with your wireing harness.
Old May 25, 2007 | 10:09 PM
andysc's Avatar
95 engine in 97Z
The car is a OBD2 and the 95 engine is from a OBD1 car. The main difference is the front timing cover. The 97 engine will have a provision for the crank sensor. You will need to swap this over in order for it to work.
HTH
andy schuck
Old May 25, 2007 | 10:54 PM
LiENUS's Avatar
HTH
andy schuck
Knock sensors are also different, just swap those out as well.
Old May 25, 2007 | 11:00 PM
bingo's Avatar
Couldn't he also use the 95 PCM and run OBD 1?
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
