engine swap
Old Mar 27, 2012 | 10:31 PM
94Maroz28's Avatar
engine swap
My 95 z28 went bad on me just bought another engine but its a 93, what parts would need to be swapped out to make things work
Old Mar 27, 2012 | 10:49 PM
dennis5374's Avatar
Re: engine swap
Hmm good question. Obviously a M.a.f sensor,your o.p.t.I,I believe the ccamshaft may even be different I'm by no means an expert but there are quite a few odds and ends that are different burning believe the short blocks are identical. Maybe someone with more knowledge than me will chime in. I own a 93 z28 but have never swapped anything other than the m.s
d o.p.t.I that is vented
Old Mar 28, 2012 | 07:13 AM
Re: engine swap
You will probably want to keep your vented opti, so you will need to swap the cam (if the 93 has a stock cam), the cam gear and the front cover. You will need to use your 95 intake/fuel rails. Most other bolted on stuff (which is not much) you just take off your old engine and put on the "new" one.
Old Mar 28, 2012 | 11:26 PM
94Maroz28's Avatar
Re: engine swap
Alright thanks, really the whole opti and cam thing was what i was worried about.
So I should be able to just swap out the cam and cover from the 95?
Old Mar 29, 2012 | 07:33 AM
Re: engine swap
The stock 93 cam does not have the large hole in the nose to accommodate the vented opti drive, so you have to swap the cam. The newer cam also gives you the longer dowel pin needed. The front cover also has to have the larger hole for the vented opti drive.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
