Engine stumble at certain RPM
Old Jun 9, 2008 | 05:41 PM
skibum's Avatar
I have been having a problem with an flat spot and stumble at about 2500 RPM's. Car runs fine at other RPM's and problem is not noticable if you run through that range. If you are cruising arond 2500 and try to accelerate car will stumble and than take off. I also noticed that when you are in neutral and and try to hold at 2500 the engine only stay there for a couple of seconds and then fall off to about 1500 and slowly back up to 2500 again. This does not happen when car is cold and that lead me to believe that it was a sensor. So far I have replaced MAF,O2sensor, MAP, and EGR. I have also had injectors serviced and flow tested and replaced fuel pressure reg and fuel pump
I did a conversion from an automatic to manual tran and had the computer reprogramed for the conversion. Could it be that there is a problem with ecm? I have also done a complete tuneup on car. I running out of idea's!
Old Sep 2, 2008 | 08:06 AM
97pontta's Avatar
Find a cure for your stumble? I also have a stumble around 2250 RPM but runs good in the highr RPMS.
Old Sep 2, 2008 | 10:55 AM
Max Lewis's Avatar
I use to have the same problem, but a tune up fixed mine. So if you have done a complete tune up plugs, wires, distributer, and checked the coil out I dont know what it could be. You might want to check for a vacum leak also.
edman
Jan 25, 2015 02:41 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
