engine stalls after running normal???
Old Aug 26, 2003 | 02:04 AM
97transamman's Avatar
hey my 93 starts and runs just fine until ive been driving for about 10-15 minutes it stalls out of nowhere. usually after slowing for a stop sign. i changed the fuel pump and it has spark and im at a loss as to what the hell the problem is, makes me angry!!! check engine light was on and now its off after i cleaned the TB with carb cleaner the idle smoothed out from the rough idle it was having but it still stalls after driving! help!
Old Aug 26, 2003 | 05:19 AM
slopokrodrigez's Avatar
After you shut the engine off, pull the vacuum line off the fuel pressure regulator and see if the hose is wet. If it is replace the regulator.
Also check and clean the EGR. When you had the TB off did you clean or check the IAC?
Old Aug 26, 2003 | 10:37 AM
i didnt check that, thanks ill try it
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
jayblev95
Dec 1, 2014 06:55 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
